139
OxygenOS 11.0.4.4 for the OnePlus 8 and OnePlus 8 Pro
  1. Ronak_Jhatakia
    Gingerbread Feb 5, 2021
    BlackJet, TrexWyo53 and Efrain2.0 like this.
  2. Grenesh Sirwani
    Cupcake Feb 5, 2021
  3. U1580007062575
  4. SIDD7411
  5. aritra123
    aritra123 , via OnePlus 8 Glacial Green , Feb 5, 2021 :
    1. Just switch off your phone
    2. Then press power button and volume down button together for 5 secs
    3. Then give your password ( if applied)
    4. Select English
    5. Select wipe cache the 2nd option
    6. Then reboot your device
  6. aritra123
  7. Xacrous
    Donut Feb 5, 2021
  8. Xacrous
    Donut Feb 5, 2021
    Xacrous , via OnePlus 8 , Feb 5, 2021 :
    I have a question since you're a oneplus 8 user. Did you face an issues with bluetooth earphone's mic not working during calls and voice/video recording?
  9. aritra123
    Efrain2.0 and Xacrous like this.
  10. aritra123
    Bro listen I faced many problems after the updates. But when do a wipe cache partition after installing the update. 90% of problems are gone. So bro try it once
  11. 1+PremWani
  12. Virajsaavn
    Cupcake Feb 5, 2021
    Virajsaavn , via OnePlus 8 , Feb 5, 2021 :
    Do i have to backup my data? Before doing this
  13. everkurt
    Honeycomb Feb 5, 2021
    everkurt , Feb 5, 2021 :
    You must explain 11.0.3.3 of the global version. Is the update not offered this time either?
    Don't ignore.
    Gabby.T, 666Syco, dlhxr and 8 others like this.
  14. P1612544720737 , via OnePlus 8T T-Mobile , Feb 5, 2021 :
    I wish they would add the Google screen call feature. It does so well at preventing robo calls or they should have their own call filtering. They also need to release security and system updates to all their phone versions. Just got the 8T+ and am worried about supporting updates on older versions of the phones.
  15. aritra123
  16. I1593116892027
    Cupcake Feb 5, 2021
  17. Virajsaavn
    Cupcake Feb 5, 2021
  18. aritra123
    #38
    RajaiBulbul and pablomartinez81 like this.
  19. G1565507869626
    Cupcake Feb 5, 2021
    #39
    Y1603743008207 and FNunes like this.
  20. sahilrana
