139
OxygenOS 11.0.4.4 for the OnePlus 8 and OnePlus 8 Pro
  1. Massmohan2400
    Cupcake Feb 11, 2021
  2. Dimi Dimitrov
    Gingerbread Feb 11, 2021
    Dimi Dimitrov , Feb 11, 2021 :
    For me is the opposite not come yet system update, but oxygen updater is latest.
    G_Chee_Seng_vsTK likes this.
  3. Massmohan2400
  4. Dr.No.pt
    Froyo Feb 11, 2021
    f0li0 likes this.
  5. Zubair.k
  6. GaryWall
    GaryWall , Feb 11, 2021 :
    You do know that Mi 11 has a SD888 SoC and OP 8, 8Pro and 8T SD865 SoC?
    Yussuan likes this.
  7. speedlever
    Honeycomb Feb 11, 2021
    speedlever , via OnePlus 8 Pro , Feb 11, 2021 :
    That's pretty relative. I'd like something more specific. Say for instance, an indicator on network info, or signal check pro, etc that indicate SA5G vs nsa5g.
  8. darshan_vaha
    darshan_vaha , via OnePlus 8 , Feb 11, 2021 :
    Heavy battery drain during standby. Running on android 11 10.0.4.4 version no.
    I have been facing very heavy battery drain since update to android 11. Is there any solution? Plz help.
    tanweerezaz1991 likes this.
  9. Chaitu9919
    Donut Feb 11, 2021
  10. 8530223143
    Eclair Feb 11, 2021
    8530223143 , via OnePlus 8 , Feb 11, 2021 :
    Thanks
  11. Zeaiclies
    Zeaiclies , via OnePlus 8 , Feb 11, 2021 :
    Other than the T-mobile's coverage map of their enhanced 5G, I do not know of any other notification for SA 5G other than the Android code *#*#4636#*#* would tell you under Data network type, if you are NSA 5G it will simply say LTE and if under SA 5G it will say LTE/SA or SA
    Perhaps the latest SOC of Snapdragon that will be in the 9 Pro will be able to provide the information, as it does contain advanced 5G bands and handling protocols and with OnePlus software be able to give advanced network information under SIM/Network.
    I understand how that might be disappointing or frustrating but it seems to be the current ways to know is Androids limited feature, or T-mobile's coverage map.
    Hopefully though it gets better.
    speedlever likes this.
  12. FromNetherlands
    Eclair Feb 11, 2021
    f0li0 likes this.
  13. abhishek_rv
    abhishek_rv , via OnePlus 8 , Feb 11, 2021 :
    Installed this update on my OnePlus 8. One issue has come up again which was resolved in previous update. Sometimes on unlocking the phone, status bar isn't visible and notification panel also doesn't show on swipe down although it is there as on swipe down and tap on the space where notification panel would be, things open up from notification panel. This issue was there before the previous update and wasn't there after previous update.
    Dimi Dimitrov likes this.
  14. B1601904056455
  15. F_Darko_Yaotzin_nMHH
  16. N1595604933954
  17. A1604937769681
  18. Gautam2403 , via OnePlus 8 Pro Ultramarine Blue , Feb 11, 2021 :
    After updating my phone to this latest version the brave browser search widget stopped working properly.
    The search box is not at all responding untill I have to open the app and then keep the app running in the background and then trying to use the search widget. Now it's working after all the shit I have to go through.....
    But no one wants to do all this and then use widget and once a person opens a app, he/she intends to search it right away in the browser only, he/she doesn't want to go through all the stuff again.
    And also I've checked with the brave browser update log and I haven't got it's updates in the last three days and the search widget was working quite fine before the oxygen os update.
    Although it did fix some bugs of the previous software update but it did brought some new into the new update(it's obvious as for a software update and I'm not blaming that..... I'm asking the developer team to rectify it) and also I do feel THE SMOOTHNESS THAT ONEPLUS CLAIMS TO BE BEST IN THE 8 PRO isn't as good as in the previous update, I do feel like touch experience of the consumer is declined.... One can easily tell the difference between 120hz display refresh rate & 240hz sampling rate and the lagging and dull user experience regarding the feel and smoothness of the software experience after the new update.😶😑
