139
OxygenOS 11.0.4.4 for the OnePlus 8 and OnePlus 8 Pro
  1. Zeaiclies
    Honeycomb Feb 13, 2021
    Zeaiclies , via OnePlus 8 , Feb 13, 2021 :
    It should
  2. Zeaiclies
    Any time a main OS is updated, you can have issues with third-party apps compatibility and need to wait for the third-party app to be updated.
  3. Andrew Krigel
    Cupcake Feb 13, 2021
  4. Thespian.
  5. M1586972348047 , via OnePlus 8 Pro , Feb 14, 2021 :
    That's the apps settings, I cannot take screenshots of bank apps, but everything else I can....
  6. Sura32
    Eclair Feb 14, 2021
    Sura32 , via OnePlus 8 Pro , Feb 14, 2021 :
    System UI crashes. I am seeing atleast couple of crashes a day! It was there before but now after software updates it's more[e]1f60f[/e]
  7. Zeaiclies
    Honeycomb Feb 14, 2021
    tiberovo likes this.
  8. Zeaiclies
    Zeaiclies , via OnePlus 8 , Feb 14, 2021 :
    Most bank apps have built-in security to not allow screen shots.
    M1586972348047 likes this.
  9. Zeaiclies likes this.
  10. Zeaiclies
  11. B1594612771619
    Cupcake Feb 14, 2021
    Batfink32 likes this.
  12. Z1592317317006
    Gingerbread Feb 14, 2021
  13. Z1592317317006
    Z1592317317006 , via OnePlus 8 , Feb 14, 2021 :
    The main issue I am facing since my last update is very slow internet speed on data network inside the house on Jio network. Will like to know has anybody the same issue? Outside the network is good and speed is also good but inside the house it is very slow. Previously it was equally good inside and outside both.
  14. Zeaiclies
    That could be a carrier service issue and that app needs an update.
    Check it in play store, mine got a new update two days after I updated to 11.0.4.4
  15. Frostywuff
    Frostywuff , via OnePlus 8 , Feb 14, 2021 :
    You need the full rom, that is only incremental update which will not work for rooted device. You should have know that before rooting.
  16. Scorpiosunset
    Eclair Feb 14, 2021
    L1589564168459 likes this.
  17. S1590616899086
    S1590616899086 , via OnePlus 8 Pro , Feb 14, 2021 :
    Hi all ,
    Does anyone have issue when sending photos/screenshots through messenger ?
    They are sent out really blurry to the other parties.
    Sometimes not readable at all of it is a text.
  18. Frostywuff
    Have you tried to format it? Don't use oneplus switch after formating, download everything fresh.
  19. Zubair.k
  20. venuchandana
    Donut Feb 14, 2021
