73
OxygenOS 11.0.5.1 for the OnePlus 7T Pro and OnePlus 7T
  1. V.V.Tretiakov , via OnePlus 7T Pro , Jan 18, 2022 :
    I can’t change how terrible things are happening with video stabilization, it’s like there’s no video to shoot, it’s not possible to blur everything into fog if it rains snow it’s just darkness, what’s happening ???
    Google maps won't open!
    Weather not working???
    The phone itself began to slow down to sign lag ???
    What's happened???
    Не могу ни как сменится что с видеостабилизацией творятся страшные вещи ее как бы нет видео снять не возможно все размывает в туман если дождь снег это просто мрак,что происходит???
    Карты Гугла не открываются!
    Погода не работает???
    Сам телефон начал тормозить подписать лагать???
    Что случилось???
    C1573534998639 likes this.
  2. Sam197
    Jelly Bean Jan 18, 2022
  3. Sam197
    Sam197 , via OnePlus 7T , Jan 18, 2022 :
    A slowdown device after 3 years is a normal thing.
  4. badflasher
    Eclair Jan 18, 2022
    badflasher , via OnePlus 7T , Jan 18, 2022 :
    Recently changed battery. I use it testing at work. Gets very hot when on charger but oh well
  5. Sam197
    Yes,mine use to get really hot when it was on charger.
  6. W1600316315562 , via OnePlus 7T Glacier Blue , Jan 19, 2022 :
    If you want to record something in recorder app it doesn't record anything
  7. A.Jeyasankar
    Gingerbread Jan 19, 2022
  8. Sam197
    Jelly Bean Jan 19, 2022
    Sam197 , via OnePlus 7T , Jan 19, 2022 :
    Give it a few days then decide
    Battery need time and the system as well,I hope you downloaded the full update
  9. Sam197
    Do reset app preferences,hope that works for you
  10. A.Jeyasankar
    A.Jeyasankar , via OnePlus 7T , Jan 19, 2022 :
    Yes I download from 10.3.8 to 11.0.5.1 (Full update via system update)
  11. W1600316315562 , via OnePlus 7T Glacier Blue , Jan 19, 2022 :
    I think my mic got damaged ,so I check in my recoder app and after saying something in the recording app it doesn't record anything
  12. Sam197
    That's sucks,you can try earphone or any Bluetooth,at least you can make phone calls till you decide if you want it to get fix or not
  13. Deepx_FTE
    Eclair Jan 19, 2022
    Deepx_FTE , via OnePlus 7T Pro , Jan 19, 2022 :
    Its ok . Go get iPhone 6 😂
  14. wtfmicky7
    Cupcake Jan 19, 2022
  15. E1576848935023
  16. V.V.Tretiakov , via OnePlus 7T Pro , Jan 19, 2022 :
    The 1 + 7t pro photo and video camera is easy to solve, wipe and remove dust particles from the laser sensor near the camera block, and the camera will start to please you again. Regarding Google maps, calibrate the compass and the maps will start working.
  17. I1609338284344
    Cupcake Jan 20, 2022
    I1609338284344 , Jan 20, 2022 :
    I am using same version, but my camera app crash when I try to open my front camera, post update
