95
OxygenOS 11.0.5.5 for the OnePlus 8 and OnePlus 8 Pro
  1. Mr.Johal
    Eclair Mar 31, 2021
  2. Vanstra
    Gingerbread Mar 31, 2021
    Vanstra , Mar 31, 2021 :
    You post in the wrong thread.
  3. SafeerNadeem
    SafeerNadeem , via OnePlus 8 Pro , Mar 31, 2021 :
    Hi There
    Yeah i tried last night but haven't been able to test the full battery drain.
    Charged 100% last night and SOT is 1hr 10 mins with 75% battery remaining.
    Last Charge(24 hrs ago).
    You can also install INBA11 by using Oxygen Updater and change your settings as attached(Also enable Advanced mode) and then download and install the latest update available.
    P1577283390953 likes this.
  4. carlosmr.martins likes this.
  5. KPlusUK
    Honeycomb Mar 31, 2021
    KPlusUK , via OnePlus 8 Pro , Mar 31, 2021 :
    Ok, so after using this phone for properly after the update, I've noticed the phone is a little more smoother. Battery life is acceptable. I mean I've had the phone on QHD and 120hz, with almost full brightness, and still getting around 4-5 hours SOT. The only let down is delay in opening an app after clicking on the notification. Again, I've had to resort to a 3rd party notification panel to get blazing fast speeds in that area.
    Overall, I'm very happy with OnePlus.
    MarkAle and denisk like this.
  6. Miscellaneous
    Donut Mar 31, 2021
    Miscellaneous , Mar 31, 2021 :
    I have no idea how you can do it, I always get around 4 hours
  7. Elijah_XVII
    Cupcake Mar 31, 2021
    Elijah_XVII , via OnePlus 8 Pro , Mar 31, 2021 :
    Speaker
    Hello folks, how are you?
    I'm having an annoying crash sound while listening a WhatsApp audio I switch from speaker to ear listening and suddenly it comes this loudly crash sound after that the audio sounds cristal clear, but that crash it annoys me.
  8. iamghouri
    Froyo Apr 1, 2021
  9. F_Tony_DeMartino_hjHI
    Ice Cream Sandwich Apr 1, 2021
    tomerrr likes this.
  10. Veer.narnoliya
    Cupcake Apr 1, 2021
  11. HetSalaaa
    Eclair Apr 1, 2021
  12. O1596275754515 , via OnePlus 8 Pro Glacial Green , Apr 1, 2021 :
    There are couple of issues I'm facing on my OnePlus 8 Pro which I'm using since August 2020.
    1. When another calls comes during an ongoing call on the earpiece, the screen lights up and as a result random options gets involuntarily pressed and selected. As long as the person is holding the phone on his ears, the screen should remain off even when there's an incoming call. It's most annoying to have the screen come on and random buttons getting unnecessarily pressed.
    2. This is happening since the last updated that sometimes the screen continuously loops between the last two opened applications on pressing the back button. Ultimately I've to come out of the loop by tapping the home button. But this happens only sometimes and mostly between the Gmail and the phone app.
    3. I've also noticed that for the past month or so whenever I restart the phone the home screen background picture comes on immediately but the icons takes a while to appear. I don't know if it's just my phone or others are also facing the same issue.
    4. When the phone is locked and the screen is off sometimes the lockscreen doesn't come on by tapping twice, instead I've to wake of up by the power button.
    Zubair.k and L1597433402437 like this.
  13. Cervantes
    Moderator Moderator Apr 1, 2021
    Cervantes , Apr 1, 2021 :
    Hello
    Please, Use the search engine before opening a new thread: Search
    Check and use the latest update thread for questions and comments, read the first post: Here
    Read the forum rules: Rules
    Post moved
  14. DPL900
    Froyo Apr 1, 2021
    DPL900 , Apr 1, 2021 :
    I don't have this options with dots in my oneplus 8
    i recovery cache partition in the following way .... 1) I turn off my mobile phone 2) I hold down the voice key 3) and now I turn on my mobile phone ... I enter the code I have for the screen lock, I select cache partition, wipe cache, and after that i reboot my OnePlus
  15. Vincenzo311002
    Eclair Apr 1, 2021
    Vincenzo311002 , via OnePlus 8 , Apr 1, 2021 :
    Op9 ha la configurazione, ho visto io stesso con la modem IMG, anche io modifico sempre la carrier policy, però mi sto stufando di dover stare ogni mese ad a modificare
    Bruno Lugnani likes this.
  16. Bruno Lugnani
    Bruno Lugnani , via OnePlus 8 Pro , Apr 1, 2021 :
    Ma si guarda, non se ne può più, comunque sia mi hanno confermato ieri che OP9PRO è abilitato solo su TIM e Vodafone, esattamente come OP8PRO mi sa che cambio marca in futuro
  17. Arun.Anz
    Donut Apr 1, 2021
  18. muharrem1961
    Gingerbread Apr 1, 2021
  19. efks
    muharrem1961 likes this.
