89
OxygenOS 11.0.5.5 for the OnePlus 8 and OnePlus 8 Pro
  1. Tejas.11_
    Froyo Apr 7, 2021
  2. AvinashThawait
    Froyo Apr 7, 2021
  3. swolfman
    Eclair Apr 7, 2021
    swolfman , Apr 7, 2021 :
    and... if these steps still do not help... factory reset the device - which always workd for me, 99% of the issues raised in this forum do not appear to me
    Kuronosu likes this.
  4. amangurung007
    Froyo Apr 7, 2021
    amangurung007 , via OnePlus 8 , Apr 7, 2021 :
    I have around 20 apps running in the background plus the app management is getting really good after few updates. Maybe try clearing cache partition.
    abubaker siddiq likes this.
  5. Kuronosu
    Gingerbread Apr 7, 2021
    Kuronosu , Apr 7, 2021 :
    Well, did you read the title? This is a post for the OnePlus 8 series, not Nord... No-one will be able to assist you with Nord related things in here...
  6. shwongdi
    Honeycomb Apr 7, 2021
    shwongdi , via OnePlus 8 , Apr 7, 2021 :
    Anyone experiencing a loss in wifi connection after this update? Idk why but my wifi keeps disconnecting quite a bit through the day.
  7. Peterxxx
    Ice Cream Sandwich Apr 7, 2021
    Peterxxx , Apr 7, 2021 :
    Now I see what you mean, it don't bother me because I have not set it to home screen only. But I understand your opinion
  8. S1592836444288
    Cupcake Apr 7, 2021
    S1592836444288 , via OnePlus 8 , Apr 7, 2021 :
    Is there any way to downgrade to OS 10???
  9. F_Teemu_Forsberg_tFal
    Cupcake Apr 7, 2021
    S1592836444288 likes this.
  10. S1592836444288
    Cupcake Apr 7, 2021
  11. iankamau42
    Cupcake Apr 7, 2021
  12. Ján Hirner
    Ján Hirner , Apr 7, 2021 :
    People, I recommend (not first and probably not last time o_O) please do this after every update (it doesnt matter which device you have from oneplus):
    1. wipe cache (not all data, beware!) through recovery: https://www.hardreset.info/devices/oneplus/oneplus-8-pro/wipe-cache/:smirk:
    2. if doesnt help, reinstall oneplus launcher from apkmirror and do wipe cache again :blush:
    3. try update again - through local upgrade method- download zip update, copy file to root directory in device and from settings do system local update (3 points menu) :relaxed:
    4. if still there are some problems, do hard reset through recovery - at first back up all data, because you will lost them by reset! https://www.hardreset.info/devices/oneplus/oneplus-8-pro/ (or also named factory reset https://www.hardreset.info/devices/oneplus/oneplus-8-pro/hardreset-second-method/ ) like said swolfman :fearscream:
  13. Ján Hirner
  14. Ca.aryadipta
    Cupcake Apr 7, 2021
  15. Vanstra
    Vanstra , Apr 7, 2021 :
    I agree with this regarding having problems, but this shouldn't be normal for regular users of an Oneplus phone after an update.
  16. Unknown1plus
  17. danyconnect
    Donut Apr 7, 2021
  18. Aaron2017
    KitKat Apr 7, 2021
    Aaron2017 , Apr 7, 2021 :
    You can disable that in settings.
    Security and lock screen>screen lock>tap the settings wheel>disable quick settings panel on lock screen
