95
OxygenOS 11.0.5.5 for the OnePlus 8 and OnePlus 8 Pro
  1. Shshank Vishwa
    Honeycomb May 12, 2021
    bpwest80 likes this.
  2. bpwest80
    KitKat May 12, 2021
    Shshank Vishwa likes this.
  3. Shshank Vishwa
  4. Athul_George
    Donut May 13, 2021
  5. ARSHATHARSH
    Cupcake May 13, 2021
  6. Carrierwave
    Eclair May 13, 2021
    Carrierwave , May 13, 2021 :
    So far other than a self induced factory reset one morning when I switch it on. Mine has been working exemplary.
    I can assure you there are much worse manufacturers out there who get good phones to market but don't have any R&D to resolve issues once at market. From what I have seen here OP actually do seem to do things, but maybe not fix everything for everyone.
    You only need to look at large companies like LG who pulled out of the market to see its not easy,
  7. Tys0nMT
  8. Tomy159
    Gingerbread May 13, 2021
    Tomy159 , via OnePlus 8 Pro , May 13, 2021 :
    Hi all,
    I have 2 thing, that was bother me in op7tpro and is there is well
    Big major problem is wifi I have 800Mbps service, unifi system with wifi 6, but phone is stuck in 60Mbps on WiFi. Even I change random mac to device mac is work for few minutes and then start blocking speed again to 60Mbps. Another brand (Samsung, huawei and xiaomi phones in my house didn't have this problem.
    (same problem was in old model OP7T pro.)
    And second is just suggestion. It is possible change it when I move finger from bottom to up is come search in app that if can change to normal Google search or Google assistant search?
  9. Peterxxx
    Ice Cream Sandwich May 13, 2021
    Peterxxx , May 13, 2021 :
    I have optical fiber internet (200 MB) and with wifi I get 206 MB with latest speed test on my OnePlus 8 pro. I think you just search the problem in your modem
  10. Tomy159
    Gingerbread May 14, 2021
    Tomy159 , via OnePlus 8 Pro , May 14, 2021 :
    Unfortunately is not. I have 2 isp so 2 independent router plus my unifi and 3 another brand phone. Non of them has problem.
    Also when I connect to one of them router separately problem persist also when Im in friends house completely different Internet and routers, problem persist.
    Don't know why, when I turn off WiFi and minute later turn on its work on full speed sometimes couple hours sometimes just few minutes.
  11. Tee_Eee_Bee
    Ice Cream Sandwich May 14, 2021
    Tee_Eee_Bee , May 14, 2021 :
    Some users have said that disabling Bluetooth helps with 5GHz wi-fi performance - not an ideal solution, though.
  12. Q1620982507766
    Cupcake May 14, 2021
    Q1620982507766 , via OnePlus 8 Pro , May 14, 2021 :
    Heat issue for One plus 8 pro is so bad
    Ambient temperature is only 35/35C
    I am using just Facebook and telegraph/ not heavy games
    Heat is rising so hot that I cannot hold my phone
    Is there any ways to fix heat issue?
    Any advices from OnePlus 8 pro users? Please
    Toreo1986 likes this.
  13. Q1620982507766
  14. kalaljatin
    Froyo May 14, 2021
  15. Vickiegowda
    Vickiegowda , via OnePlus 8 Pro , May 14, 2021 :
    By playing 1 game of pubg my phone heats like hell....even il get a notification from android saying ur phone temperature is max so brightness will b reduced .....for only 1 game this is happening for so many times .....
  16. anmol.butta
  17. Aaron2017
    KitKat May 14, 2021
    Aaron2017 , May 14, 2021 :
    They dont give ETA's on updates, but most likely at the end of this month.
  18. Ananthu6
    Froyo May 15, 2021
    Ananthu6 , via OnePlus 8 Pro , May 15, 2021 :
    The battery drain during games is huge ....for example I played Hitman sniper for around 30 mins and battery dropped around 10% plz fix this issue {Hitman is just an example ok ...it happens on many games }.....overall the battery backup has dropped after new updates.....and plz add black ui and a toggle to easily switch between ring, vibrate and silent modes in drop-down menu..... thank-you in advance.....
    I hope you will take my suggestion OnePlus 🥺😊
  19. Peterxxx
    Ice Cream Sandwich May 15, 2021
    Peterxxx , May 15, 2021 :
    You have a physical toggle for ring, vibrate and ring mode ;)
  20. Ananthu6
    Froyo May 16, 2021
    Ananthu6 , via OnePlus 8 Pro , May 16, 2021 :
    Yes I get that but in the long run the physical switch will break or go wrong what then ?
    Carallo29 likes this.
