95
OxygenOS 11.0.5.5 for the OnePlus 8 and OnePlus 8 Pro
  1. Noitron
    Donut May 21, 2021
  2. amitnpz
    Donut May 21, 2021
    amitnpz , via OnePlus 8 Pro , May 21, 2021 :
    I m using the same with no problems at all. Try doing a factory reset.
    f00tbaLL likes this.
  3. Shouvik1plus
    Froyo May 21, 2021
  4. Peterxxx
    Ice Cream Sandwich May 21, 2021
    Peterxxx , May 21, 2021 :
    I have no bugs on Android 11
    DPL900 likes this.
  5. Peterxxx
    Maybe I will a millionaire in the long run, or not....
  6. Auris_ likes this.
  7. Shouvik1plus
    Froyo May 22, 2021
    Shouvik1plus , via OnePlus 8 Pro , May 22, 2021 :
    Bugs means heating issue , lagging , battery drains fast . Are these your are facing after update to Android 11 in your one plus 8 pro ?
  8. Tomy159
    Gingerbread May 22, 2021
    Tomy159 , via OnePlus 8 Pro , May 22, 2021 :
    Yes I didn't have any of this issue either.
    But maybe because I was do clean install. First upgrade then factory reset twice and then setup phone again.
  9. Shouvik1plus
    Froyo May 22, 2021
    After upgrading , if I do factory reset imy Android will remain on Android 11 by default ?
  10. Tomy159
    Yes it will. Is normal upgrade.
  11. Shouvik1plus
    Froyo May 22, 2021
  12. Ananthu6
    Froyo May 22, 2021
    Ananthu6 , via OnePlus 8 Pro , May 22, 2021 :
    Plz OnePlus help .......when I lower my screen brightness of OnePlus 8 pro {indian version} to almost minimum and open YouTube app in dark mode everything has green tint....the videos and all the gray areas this is issue is only on low brightness...on earliest version which came with the phone there was not one issue now after android 11 this is one issue. The 2nd is on lockscreen of there is a notification in gray there is a slight redness to it again only if the screen brightness is low😭😭😭😭😭
    and huge green tint throughout ui on all Gray's....... if it's set to low brightness and 60 hz refresh rate which wasn't there till the latest update 😡😡😡{fix this or give us complete pitched black material ui😤}
    PLZ ONEPLUS FIX THE ISSUES BEFORE GIVING NEW FEATURES ETC....AND PLEASE DON'T MAKE Z UI WHICH IS BETTER THAN MOST BY GIVING US USERS MORE BUGS THAT WASN'T THERE BEFORE.....THE ONEPLUS 8 PRO ISN'T CHEAP OK PLZ FIX THE ISSUE 🙏🙏🥺
    AMAL_SABU and Shouvik1plus like this.
  13. Ananthu6
    Froyo May 22, 2021
    Ok so I haven't done factory reset on my phone after android 11 update it has few issues after updating {like green tint on YouTube in very low brightness and on gray areas of ui etc}...so should I do it and if I do will it fix them ?......if I do factory reset through settings will it brick or something ?
    {I have updated through ota and haven't done factory reset till now after I updated the phone }
  14. Peterxxx
    Ice Cream Sandwich May 22, 2021
    Peterxxx , May 22, 2021 :
    none of the bugs you describe
  15. Shouvik1plus
    Froyo May 22, 2021
  16. Shouvik1plus
    Froyo May 22, 2021
    Have you contact the support team with a screenshot ?
  17. Sado0og
  18. Peterxxx
    No i have the European version
    DPL900 likes this.
  19. Gilles44
    Aaron2017 likes this.
