95
OxygenOS 11.0.5.5 for the OnePlus 8 and OnePlus 8 Pro
  1. aritra123
    Honeycomb Mar 30, 2021
  2. mohitkmr28
    Eclair Mar 30, 2021
  3. KPlusUK
    KPlusUK , via OnePlus 8 Pro , Mar 30, 2021 :
    Done the update. Nothing major to feedback on as the update has not made the device any better or worse. I had a small issue with notifications not opening up some apps quick, like WhatsApp, after clicking on them. But this update hasn't fixed this issue. Hopefully, the next update will.
  4. dpbasu
    Froyo Mar 30, 2021
    dpbasu , via OnePlus 8 , Mar 30, 2021 :
    Hi, since the last 3 updates, the quick settings toggle icons show up with a noticeable delay when swiped down from any screen. I cannot provide any log for that as it is not always replicable. This has happened after the second update in OOS 11. I hope OOS team notices this and tries to fix this issue. It's not fixed in 11.0.5.5. I'm using a OnePlus 8.
  5. Hgogny
    Cupcake Mar 30, 2021
  6. varfirdous
    Eclair Mar 30, 2021
  7. Mayank_soul
  8. Abbas1103
    Froyo Mar 30, 2021
  9. Mayank_soul
    Hari_Kalati, mridul28, ANTHLD and 2 others like this.
  10. kishore greesan
    Eclair Mar 30, 2021
    kishore greesan , via OnePlus 8 , Mar 30, 2021 :
    Instagram isn't responding and it is getting stopped when I open after updating this.
    If anyone has any idea why it is happening and has a solution . kindly let me know.
  11. kalaljatin
    Froyo Mar 30, 2021
    aritra123 and Abbas1103 like this.
  12. kalaljatin
    Froyo Mar 30, 2021
    Nitingup00 and Abbas1103 like this.
  13. GaryWall
    Gingerbread Mar 30, 2021
    GaryWall , Mar 30, 2021 :
    Prefect update, no problems at all. Using the OP8 heavily with games and apps and the only difference I have noticed is that the battery time seems to have improved. It may be a bit early to tell if it is a permanent increase in SOT for me it was rather good even with the old firmware.
    Everything works just like it did before. So basically, the only benefit for me is the march 2021 security patch.
  14. virtser
    Donut Mar 30, 2021
  15. bikerboy360
    bikerboy360 , Mar 30, 2021 :
    Instagram error not the update.
    Hari_Kalati, f0li0 and Abbas1103 like this.
  16. bikerboy360
    Rolling back to the older version of instagram helps for now.
  17. kishore greesan
    Eclair Mar 30, 2021
    I just tried reinstalling instagram. Now it is working. But I think it is temporary solution. Let me update you if same happens again.
  18. U1617118342815
    U1617118342815 , via OnePlus 8 Pro , Mar 30, 2021 :
    Android 10 and Oxygen Os 10 is more reliable and smooth rather than Android 11 🧐 I used android 10 in oneplus 7t before switching to oneplus 8 pro which doesn’t fix lagging or other issues yet
  19. ankurbhoot
