138
OxygenOS 11.0.5.6 for the OnePlus 8T
  1. SalamHusin78
    Gingerbread Dec 29, 2020
    SalamHusin78 , via OnePlus 8T , Dec 29, 2020 :
    Could not go through via local update mode? Are you on Hydrogen and which update is that?
  2. Sergeant_Ozzy
    Cupcake Dec 29, 2020
    Sergeant_Ozzy , via OnePlus 5T , Dec 29, 2020 :
    Local update tells me that my version number is too low, despite it being the same version (11.0.5.6, haven't updated it yet). Was going to go the OnePlus store in my city and just get them to do it if all else fails, but as they only speak Chinese it might be a little tricky so I wanted to check all my options first.
    I'm on Hydrogen OS.
    SalamHusin78 likes this.
  3. sephiroth
    sephiroth , Dec 29, 2020 :
    Because the compile time on HOS is later then OOS on this version:
    OnePlus8TOxygen_15.O.20_OTA_0200_all_2011132216_a6374d5b0e134ca7.zip
    OnePlus8THydrogen_15.H.20_OTA_0200_all_2011172228_979264063be.zip
    So you can't update from HOS to OOS (it's OK vice versa though), I've been on this situition and my way is to rollback the ROM and update to new version again:
    https://forum.xda-developers.com/t/...l-to-restore-your-device-to-oxygenos.4180837/
    But this will wipe all data and settings on the device.
  4. Sergeant_Ozzy
    I'm fine with it wiping my data as I haven't actually used the phone much (incase this very thing happened). Just to check though, it won't void my warranty will it? I've heard mixed results of people's phones bootlooping after doing something like this. Is it safe to do?
  5. sephiroth
    I've tried this many times (on older version OOS though) and no issues if you followed all the instructions on the above link, from HOS to OOS, or OOS DA to AA to BA and vice versa. But I don't know if this will void the warranty(I think not since oneplus phones don't need to unlock like XiaoMi).
  6. Sergeant_Ozzy
    Cool, thanks for your help man. I'll give this a go after work tonight. Looking forward to finally getting to use this phone!
  7. SalamHusin78
    Probably you could resolve via msm download tool for the said full OTA zip file. Technically maybe quite difficult to execute but you could give a try. Explore xda developers if you are keen to do your research first.
  8. Suresh_Jayachandran
  9. Pochinki
    Froyo Dec 29, 2020
    Pochinki , via OnePlus 8T , Dec 29, 2020 :
    You can download the new update for 8T 11.0.6.7 full rom. Try flashing that.
  10. Cervantes
    Moderator Moderator Dec 29, 2020
    Cervantes , Dec 29, 2020 :
    Hi
    What other unlocking options do you have activated?
    Smart lock
    connected watch
  11. padmakumarbs
    Froyo Dec 29, 2020
  12. AstroBee
    Froyo Dec 29, 2020
  13. authenticdemon
    Froyo Dec 29, 2020
    T1514829450825 likes this.
  14. AstroBee
    Froyo Dec 29, 2020
  15. T1514829450825
    Eclair Dec 29, 2020
    T1514829450825 , via OnePlus 8T , Dec 29, 2020 :
    I updated my OnePlus 8t today but i am having problem in youtube ,while watching videos on youtube they always buffering in the high speed data ,before this software update it was working fine,but after update i can't play videos on youtube, help..
    padmakumarbs likes this.
  16. ShreyasPatil_
    Jelly Bean Dec 29, 2020
    ShreyasPatil_ , via OnePlus 8T , Dec 29, 2020 :
    found a fix.
    I just setted screen refresh rate to 60 Hz and rebooted. It was unchecked after the update. And after the reboot videos were playing smoothly. After that enabled 120Hz and it's working fine now.
    burnout123 likes this.
  17. T1514829450825
    Eclair Dec 29, 2020
  18. AstroBee
    Froyo Dec 29, 2020
    AstroBee , via OnePlus 8T , Dec 29, 2020 :
    Not working for me
  19. ShreyasPatil_
