37
OxygenOS 11.0.6.6 for the OnePlus 8 and OnePlus 8 Pro
  1. cyberman_5145
    Honeycomb May 30, 2021
    cyberman_5145 , via OnePlus 6T , May 30, 2021 :
    After updating my OnePlus 8 to 11.0.6.6 and post 3 days of use here is what I have experienced:-
    1. Battery drain is massive on stand by. Android system, mobile network and system idle shows nearly 13% battery usage which is way too odd for a device to loose.
    2. Wifi disconnection is still there. No change to stability.
    3. Security patches are updated , yes they are the only thing I saw worth updating my device for.
    4. Device heating issue - it's not that much however at times it's annoying and wasn't the case for me on 11.0.5.5
    5. Lags and frame drops - Device now lags a bit more than previous version. Wonder what was this update rolled to fix.
    6. Gallery app is slow but kinda ok but not worth on OnePlus 8 considering this is a flagship with SD865 series. My OP6T running SD845 is more fluid and smooth then my 8.
    Overall for me this update is another mess and only brings security patch update nothing more. We as OnePlus customers are again fooled at hands of China's phone brand which I regret relying on all this while... This is indeed my last OnePlus device. I believe Samsung or iphone is my absolute choice for any new device I would be buying....!!
  2. cyberman_5145
    Hahaha... Now that statement just made my day bro.... I echo you here... Somethiyis added to this update no wonder we asked for it or not but they did serve us few more unwarrantbugs....😜😜
    Parthkansara likes this.
  3. Tee_Eee_Bee
    Jelly Bean May 30, 2021
  4. mkfh2000
    Cupcake May 30, 2021
  5. Tee_Eee_Bee
    Tee_Eee_Bee , via OnePlus 8 Pro , May 30, 2021 :
    I don't think they have released it yet
    It's also not available via oxygen updater
    Edit: the incremental version is available via oxygen updater.
  6. Shshank Vishwa
    T1611303080565 likes this.
  7. W1508491554407
    Gingerbread May 30, 2021
  8. agnibhasarkar
  9. L1603638359927
    L1603638359927 , via OnePlus 8 , May 30, 2021 :
    Just update. Random system ui crash still remains....
    One year since release. 10 monts for holding this device abd you haven't fix this issue.
    What are you doing during first year?
    Increase product lines?
  10. KPlusUK
    KPlusUK , via OnePlus 8 Pro , May 30, 2021 :
    Unfortunately, the new update isn't as good as I first thought it was. I'm experiencing lags when opening and closing apps. This is so frustrating.
    EDIT: I've installed a fresh copy of 11.0.6.6 and this seems to have made a difference to my mentioned issues. I'll keep everyone posted.
  11. T1611303080565
    T1611303080565 , via OnePlus 8 Pro , May 30, 2021 :
    After updating my OP 8 pro during call when i kept over speaker mode the voice quality is so cheap specially another person cant able to hear it properly although i am shouting loudly
  12. ottafish
    Eclair May 30, 2021
    ottafish , via OnePlus 8 Pro , May 30, 2021 :
    Cleared cache
    Ran update and installed
    Cleared cache
    Phone is performing very well.
    Everything works as expected
    No problems here.
    We'll done Oneplus Team
    Love your work. [e]1f44d[/e]
    GaryWall, Langesmalle, KloNoS and 6 others like this.
  13. MoeBen
  14. swolfman
    Froyo May 30, 2021
  15. Hrishabh Gautam , via OnePlus 8 Pro Ultramarine Blue , May 30, 2021 :
    Do you have any fingerprint issues in any of your App locks of your OP 8 PRO ?
  16. AmolChaugule
  17. anmol.butta
  18. L1614709317045
