75
OxygenOS 11.0.7.7 for the OnePlus 8 and OnePlus 8 Pro
  1. U1590746344532
    Cupcake Jun 13, 2021
    U1590746344532 , via OnePlus 8 , Jun 13, 2021 :
    Found a bug. When unlocking the device, at certain times the notification panel disappears all together, even time, notification icons at top, battery level indicator and all disappear and the brightness goes to max.
    Certain times when unlocking it just shows the wallpaper, and everything else disappears, app icons, widgets , Google search bar all disappear.
    Locking the device and unlocking is what I have to do in order to bring it back to normal, but this happens frequently.
    - Leander
  2. amitnpz
    Eclair Jun 13, 2021
  3. G1623077792831
    G1623077792831 , via OnePlus 8 Pro , Jun 13, 2021 :
    5.5-6hrs in FHD. I dont play game, just social media or web browser. If i take photos or videos for a while, the SOT is about 4.5-5hrs.
    ottafish and Muhimin_Osim like this.
  4. jorgegh
    jorgegh , Jun 13, 2021 :
    After this update, if I try to share screen with an smart tv (LG with WebOS) and disconnect, the phone goes crazy, It's like the screen is wet and produces false touches and I can't unlock with fingerprint or pattern. After reboot all works fine again. Has this happened to anyone else?
  5. wildecooke
    Eclair Jun 13, 2021
  6. Kata40
    Froyo Jun 13, 2021
    Kata40 , Jun 13, 2021 :
    How? În 6-7 hours mine is finished
  7. James2117
    James2117 , via OnePlus 8 , Jun 13, 2021 :
    After the update finger print is not working well in certain apps n my display use to flash while playing games n the fps use to drop n my phone become laggie idk what is happening
  8. Navin100
    Gingerbread Jun 13, 2021
    Navin100 , Jun 13, 2021 :
    Everything is fine and working good with my OnePlus 8 pro set to full hd 120 fps no heating issue and not even found any bug till now everything is perfect like when it launched getting 4+ hours SOT with 42% left and I didn't wipe my cache.....so don't worry everyone can update
    Muhimin_Osim and R1596738484841 like this.
  9. R1596738484841
    Donut Jun 13, 2021
    R1596738484841 , via OnePlus 8 , Jun 13, 2021 :
    I did this in my OnePlus 8, issue still persist
  10. sp5it
    sp5it , Jun 13, 2021 :
    They changed patch location, worked before.
  11. IqbalSingh98
  12. lequime
    Froyo Jun 13, 2021
    lequime , via OnePlus 8 Pro , Jun 13, 2021 :
    No 5G, no VoLTE or VoWIFI with the OnePlus 8 Pro and the latest firmware 11.0.7.7 with the provider Swisscom.
    Sunrise seems to work, also Swisscom with the 9 Pro... The OnePlus support is absolutely unable to communicate anything about that.
    Every question asked to the support results in standard answers they take from their box...
  13. markus.hicks15
    markus.hicks15 , Jun 13, 2021 :
    Anyone have any issues with WIFI since the update? my device has been disconnecting constantly since I updated despite all other devices I have remaining connected with no issues. I have not went more than 10 minutes connected to the network without it disconnecting and me having to manually connect.
  14. Yashdolas
    Gingerbread Jun 14, 2021
  15. Dimi Dimitrov
    Honeycomb Jun 14, 2021
    Dimi Dimitrov , Jun 14, 2021 :
    Wow,after all this complain about sim issue,I will not update for now.
    Yashdolas likes this.
  16. Gilles44
    Gilles44 , via OnePlus 8 , Jun 14, 2021 :
    After OxygenOS 11.0.7.7 update battery doesn't drain if I clear cache and read the posts in this thread.
    Just repeat this sentence above twice a day during 2 weeks and you won't have issues like that anymore.
    Yussuan likes this.
  17. O1603940535803
    Cupcake Jun 14, 2021
    aoyanb likes this.
  18. Sudarsen
    Donut Jun 14, 2021
    Sudarsen , via OnePlus 8 , Jun 14, 2021 :
    Why was this smaller update pushed after the security update which seems a bit odd. Actually my phone performed better after the security update. Then this one came and performance was deteriorated.
