74
OxygenOS 11.0.7.7 for the OnePlus 8 and OnePlus 8 Pro
  1. Panda_Learns
    Gingerbread Jul 23, 2021
  2. Raduk
    Cupcake Jul 23, 2021
    Raduk , Jul 23, 2021 :
    Some UI tweaks and unified code between Oxygen OS and Color OS.
    Panda_Learns likes this.
  3. Panda_Learns
    Panda_Learns , via OnePlus 8 Pro , Jul 23, 2021 :
    Should be something significant if there is so much difference but I guess, that's behind the scenes. A
    Thanks!
    Raduk likes this.
  4. AzretKhan , via OnePlus 8 Pro Ultramarine Blue , Jul 23, 2021 :
    the smartphone heats up all the time, the battery drains quickly, everything is just as terrible as before, but now the phone is also hot and sits down quickly. it's time for the company to close, the product has become terrible, I recently bought a 9pro, This model is even worse, not even there filedash.
    last good oneplus is 7t pro, and you can block me or do whatever you want, but everything that you did after 7t pro is about this complete shit...
    You just become as lame as Samsung, and with each new model you lose your individuality and our interest in you.
    I had your models 5, 6t, 7,7t pro, 8pro, 9pro, as well as 8t. I used all of them, and they all made me happy up to 7t pro inclusive, starting from 8, everything got worse, apparently it will be even worse further ...
    Oneplus died for me 😞 ...
  5. MarkusRanz
    Ice Cream Sandwich Jul 23, 2021
    MarkusRanz , Jul 23, 2021 :
    do you habe a Link to a Thread about the Apps we need to delete via adb?
  6. G1594644711110
  7. Sid@p
    Froyo Jul 23, 2021
    Sid@p , via OnePlus 8 Pro , Jul 23, 2021 :
    Same issue here too, please suggest
  8. J1627101343657
    Cupcake Jul 24, 2021
    J1627101343657 , Jul 24, 2021 :
    So I got a brand new OnePlus 8 last week and already unlocked bootloader. I then looked up how to root the device and found this thread with the different Oxygen region versions.
    After reading through a few other forums and comparing versions numbers etc. I'm not that sure which version I should download to extract the boot image.
    My OnePlus says it has the version "11.0.7.7.IN21BA" which is the EU one.
    At the beginning of this thread there are these three regions/versions listed:
    IN: 11.0.7.7.IN21DA
    EU: 11.0.7.7.IN21BA
    NA: 11.0.7.7.IN21AA
    When I now go to the German download page (https://www.oneplus.com/de/support/softwareupgrade/details?code=PM1586920535300) it displays the version "11.0.7.7.IN21DA" but that is version for India, right?
    Also found this site (https://www.thecustomdroid.com/download-oneplus-8-pro-oxygenos-ota-updates/) which has the correct version/region for my phone (the "11.0.7.7.IN21BA").
    The part where I now get confused is I calculated the md5-hash from the above mentioned file and compared it to the one displayed on the German download site and it matches!
    There are now two options; either the file on the German download site is the Indian one or they simply just misspelled it.
    Can anyone help me out here?
    I.e. can I use the file I've downloaded from the www.thecustomdroid.com website to extract the boot image from and root my device?
  9. Yuri.Katzlowski
    Froyo Jul 24, 2021
    Yuri.Katzlowski , via OnePlus 8 , Jul 24, 2021 :
    J1627101343657 likes this.
  10. OneplusLover.
    Gingerbread Jul 25, 2021
    OneplusLover. , via OnePlus 7 Pro , Jul 25, 2021 :
    OnePlus 8 & 8 pro users :- Where's this month bug fixes and security patch🥸!
    OnePlus- Roses are red Shit is Brown , Shut the F up and Sit the F down !
    (SAD REALITY ABOUT ALL CHINESE COMPANIES)
    (MIDDLE FINGER SHOWN TO ALL INDIAN USERS)
    Nitingup00 likes this.
  11. OneplusLover.
  12. Mahesh nayak
    Donut Jul 25, 2021
    Nitingup00 and GarikOnePlus like this.
  13. OneplusLover.
  14. O1590779494020
    Eclair Jul 25, 2021
    O1590779494020 , Jul 25, 2021 :
    https://forum.xda-developers.com/oneplus-7-pro/how-to/increase-battery-life-t3939843
    https://forum.xda-developers.com/oneplus-6/how-to/adb-oxygen-os-debloat-solution-t4015733
    https://www.xda-developers.com/uninstall-carrier-oem-bloatware-without-root-access/
    Some entry points to start with
    Be careful!
    You may set your password to pattern first, in case you crash your keyboard you can not login anymore and have to factory reset. This always can happen also due to a faulty gboard update btw. There is no fallback in the main system, only in recovery system, quite stupid, if you have chosen password as main login then. Another weakness.
    I also would let adb debugging switched on during this time so you could always reinstall software which you uninstalled before.
    Do not just run batchfiles blindly, check their contents before. You may still need some stuff. Not all stuff really uses battery. A good start is to use glassdoor first and write down all major users of data. Are there programs talking to the internet you dont want to? Usually only google fcm should not be blocked, as most push programs rely on it.
    Good luck.
  15. Mehedi13037.
    Donut Jul 26, 2021
  16. Tee_Eee_Bee
    Ice Cream Sandwich Jul 26, 2021
    Tee_Eee_Bee , Jul 26, 2021 :
    You can try changing the support page you are visiting at the bottom of the web page. Maybe if you select another European site it may show the EU version.
  17. Tee_Eee_Bee
    When Google release it officially later this year.
    Caomhin likes this.
  18. Tee_Eee_Bee
    According to OnePlus's software maintenance schedule, stable version releases are approximately every two months, 11.0.7.7 was released on June 9, so expect the next stable update around early August.
    Antonygeorge99 and Caomhin like this.
  19. Mehedi13037.
    Donut Jul 26, 2021
  20. N1596706250072
    Cupcake Jul 27, 2021
    N1596706250072 , via OnePlus 8 , Jul 27, 2021 :
    Does anyone facing call is getting disconnected automatically after few seconds or minutes and volume button automatically tries to adjust the volume while on call.
