40
OxygenOS 11.0.7.7 for the OnePlus 8 and OnePlus 8 Pro
  1. efks
    Ice Cream Sandwich Jun 11, 2021
  2. Dimi Dimitrov
    Gingerbread Jun 11, 2021
  3. Tomás Gonçalves
    Eclair Jun 11, 2021
    Tomás Gonçalves , via OnePlus 8 , Jun 11, 2021 :
    Regarding tips, all I do is go to Settings > Battery > Battery optimization and make sure all non important apps are set to Optimal. By default all are set to Intelligent Control. Only do this for apps you installed or some Google apps you don't care for. Do not do it on critical or system apps.
    I charge my phone only once a day, as I do not allow myself to charge it twice ever, to do as little charging cycles as possible and keep the battery healthy. Once the phone reaches 0% and shuts down I use my other phone or even my laptop. I would recommend you to let your battery reach 0% and charge it all the way to 100% with the Warp charger but don't let the charger stay connected once the battery is fully charged either.
    Keep your screen brightness as low as you can while being able to look at the screen without stressing your eye sight too much.
    I only enable Battery saver once phone reaches 15% by the way, otherwise it's always off. Location is always off too unless I need it for something and I also turned off Digital Wellbeing and usage access for most apps that aren't essential to me.
    Edit: Screen is always running at 90hz (unless capped by the game or app) and set to Vivid color setting. Dolby Atmos is always on but without Earphone Adjustment presets active.
    Carrierwave likes this.
  4. Sokkka
    Cupcake Jun 11, 2021
  5. rachit_asia , via OnePlus 8 Pro Glacial Green , Jun 11, 2021 :
    OMG my friend, I have exactly the same settings as mentioned. Just the refresh rate is set to 120 Hz. So ideally the backup should be the same and good.
    Tomás Gonçalves likes this.
  6. iamghouri
    Froyo Jun 11, 2021
  7. O1587725067000
  8. Ján Hirner
    Honeycomb Jun 11, 2021
  9. leekimah
  10. Peterxxx
    Peterxxx , Jun 11, 2021 :
    Yes, in the Netherlands the update is available
  11. speedlever
    speedlever , via OnePlus 8 Pro , Jun 11, 2021 :
    Kudos to OP for the quick security patch update to June this early! Hope to see this more often going forward!
    Great job OnePlus!
    No known issues after the upgrade on my 8 pro.
    Muhimin_Osim likes this.
  12. swolfman
    Eclair Jun 11, 2021
  13. speedlever
    I completely agree. Been following this routine since my op3 to my 8 pro and never have issues that can't be easily fixed.
    And if I ever see odd battery issues with unusual processes, I boot into recovery and wipe the system cache and that just seems to fix many minor issues in my experience.
    It may not be a fix-all, but it's saved me from having to do a factory reset.
    V1622892201471 and Gilles44 like this.
  14. Gilles44
    Gilles44 , via OnePlus 8 , Jun 11, 2021 :
    For sure, but you can also do this just to avoid encountering issues, no ?
  15. cuenca
  16. Tomás Gonçalves
    Eclair Jun 11, 2021
    Oh, you have the OnePlus 8 Pro and you don't get 7-8h of SOT? That's weird. The battery is bigger. Maybe try lowering the screen refresh rate to 90hz and report back?
    Here's proof btw:
  17. jewelraj
    jewelraj , Jun 11, 2021 :
    I have oneplus 8 pro IN2023 model European version. I wasn't get this update OS 11.0.7.7.IN11BA. I get this OS 11.0.7.7.IN11AA. Why i get the 1AA version. I should have got it IN11BA version?? I don't live in europe.. I lives in bangladesh..
  18. jewelraj
    yesterday, thursday the update of EU version is available.. please check the photo. is this the update of EU version. Device oneplus 8 pro IN-2023
    Yunuskamal likes this.
  19. Peterxxx
    I think it's because you live in Bangladesh. Then you get automatically that region version. If you want other version than download the oxygen updater app in playstore and set is up like your in Europe for example
  20. Peterxxx
