129
OxygenOS 11.0.7.9 (IN & NA) and 11.0.7.10 (EU) for the OnePlus 8T
  1. egemen359
    Eclair Feb 10, 2021
    egemen359 , via OnePlus 8T , Feb 10, 2021 :
    The worst one is whatsapp, but almost the all apps wait to open 0.5-1 sec in notification. AA build too, i wipe data and cache, still same. Dont know. Its weird
  2. EdRahool
    Eclair Feb 10, 2021
    EdRahool , via OnePlus 8T , Feb 10, 2021 :
    Maybe a full reset will help you.
    I just re-checked and there is no delay, clicking on notification instantly open up the app window.
  3. egemen359
    Eclair Feb 10, 2021
    How can i full reset of the phone sir? I wiped data already.
  4. EdRahool
    Eclair Feb 10, 2021
    Wipe date helps but if you are facing a delay issue you can backup your date and do a factory Reset.
    I do feel they have iron out lot of animations issues and delay issue in this update.
    Definitely feel more smooth now.
    Bernest44 likes this.
  5. egemen359
    Eclair Feb 10, 2021
    I will try factory reset from settings thank you, but i think it wont work anyway, wipe data didn't work too
  6. GianniP89
    Froyo Feb 10, 2021
    Bernest44 and burnout123 like this.
  7. egemen359
    Eclair Feb 11, 2021
    Nk_rajput__ likes this.
  8. [email protected]
    Gingerbread Feb 11, 2021
    [email protected] , via OnePlus 8T , Feb 11, 2021 :
    For those with issues how many of you are rooted? If your not then you should always factory reset when problems arise..... Bad battery and poor camera won't get fixed though.
  9. Z1610707551094
    Cupcake Feb 11, 2021
  10. pradeeponlyurs
  11. imcrazyz
    imcrazyz , Feb 11, 2021 :
    Can anyone comment on the stability of this update? Does it have any major bug?
  12. Sach!
    Froyo Feb 11, 2021
    Sach! , via OnePlus 8T , Feb 11, 2021 :
    update is good . battery seems good as well im getting 6hrs sor vs the latter which is 4.5hrs sot
    _ please fix hrss and minss
    _still 4g/5g switching bug still remains will automatically put you on 3g which 4g and 5g is available in the area you have to disable 5g for the network will put you on 4g else it will be on 3g
    Nikhil_Bhilai likes this.
  13. Ken_Brownstone
  14. O1544612221504
  15. Richard C. Mongler
  16. AdityaVS
    Donut Feb 11, 2021
    AdityaVS , via OnePlus 8T , Feb 11, 2021 :
    I am from India and have updated to this version the day it launched. The update is not well optimised, it is bringing UI stutters and frame drops while gaming. Sometimes need to restart the phone to make everything normal and smooth. I recommend not to flash this version. Waiting for next update to resolves my issues.
  17. M1605849462403
  18. florincostescu
    Ice Cream Sandwich Feb 11, 2021
    egemen359 likes this.
  19. sourink
    Eclair Feb 11, 2021
  20. DionoiD
    Donut Feb 11, 2021
