126
OxygenOS 11.0.8.12 (IN & EU) and 11.0.8.11 (NA) for the OnePlus 8T
  1. S1559903173085
    Gingerbread Mar 29, 2021
    #81
  2. Arvindlakra_21
    Froyo Mar 29, 2021
    #82
  3. Vatsal8286
    Eclair Mar 29, 2021
    Vatsal8286 , via OnePlus 8T , Mar 29, 2021 :
    did everything but no luck...Netflix deleted still no luck what to do?
    #83
  4. Vatsal8286
    Eclair Mar 29, 2021
    it's true getting long backup but no WIDEVINE L1 support...
    #84
  5. lalitpnl16
    lalitpnl16 , via OnePlus 8T , Mar 29, 2021 :
    I did the below unknowingly and it worked. Just don't know how.
    Go to google play store>settings>biometric authentication. If the toggle is disabled, just enable it. If prompted to enter password, enter it.
    Reboot the phone once and check the widevine status using the DRM info app from the play store. Probably check back in some hours if not immediate
    It should corne back to L1.
    If Netflix is still showing SD, go to Netflix app info, clear cache, data and uninstall updates. Reboot, install updates and check out the playback specification.
    I also noticed that it drops to L3 on a random basis if battery is also low. Rebooting the phone once or twice successively brought it back to L1 after connecting to the charger.
    #85
  6. srini0301
    Jelly Bean Mar 29, 2021
    srini0301 , Mar 29, 2021 :
    Battery draining mostly depends on your applications installed , location always on . Don't compare with others they will be using different applications usage scenarios are different . Check u r battery draining applications and take care of them .
    #86
    TheMystic and G_Mr_.... like this.
  7. kushal_s1296
    Donut Mar 29, 2021
    #87
  8. Arvindlakra_21
    Froyo Mar 29, 2021
    Arvindlakra_21 , via OnePlus 8T , Mar 29, 2021 :
    Last resort would be to contact service center. They will fix the issue.
    #88
  9. Vatsal8286
    Eclair Mar 29, 2021
    I did all the steps..still no luck since 1 month
    #89
  10. Shourobh
    Eclair Mar 29, 2021
    Shourobh , via OnePlus 8T , Mar 29, 2021 :
    Thats netflix app problem try to uninstall and reinstall ....
    #90
  11. srini0301
    I got error message as device failure after update . I closed and re opened Netflix , it's asking me to enter my login credentials and it's fine now .
    #91
  12. Greydrako
    Cupcake Mar 29, 2021
    #92
  13. W1616483235051
    #93
  14. BillyFox
    Eclair Mar 29, 2021
    BillyFox , Mar 29, 2021 :
    have you contact with Netflix?
    #94
  15. Dharanidharan551
    Eclair Mar 29, 2021
    #95
    S1559903173085 likes this.
  16. S1559903173085
    S1559903173085 , via OnePlus 8T , Mar 29, 2021 :
    Good...but buying this OnePlus is a waste any more. Today 20k samsung mobile s r far far better. These OnePlus r cheating
    #96
    Dharanidharan551 likes this.
  17. Shivnshkhatana
    Froyo Mar 29, 2021
  18. Dharanidharan551
    Eclair Mar 29, 2021
    #98
    Loki10 likes this.
  19. Dharanidharan551
    Eclair Mar 29, 2021
    Dharanidharan551 , via OnePlus 8T , Mar 29, 2021 :
    Ss 43000 rupees price for 8T is bit on higher side. But now a days VIVO give good phones with good OS. I love oxygen OS that is without any ads. Some big drawback in 8T are
    1. primary camera sensor
    2. screen flickering in low brightness dark mode
    #99
    Seetam and S1559903173085 like this.
  20. S1559903173085
    Any one interested in filling consumer case in India against OnePlus. Kindly come together...so that we can share the legal expenses also file the case in different cities. These OnePlus guys looting and cheting consumer s. I am from Bangalore, I really find the OnePlus guys are horrible and pathatic. Guys pls reply...let us not let these companies to fool us in India.
    osama9, SureshNandhu and Wishnu_Mohan like this.
