45
OxygenOS 11.0.9.9 (EU & NA) for the OnePlus 8T
  1. Evgenij_
    Eclair Aug 3, 2021
    Evgenij_ , via OnePlus 8T , Aug 3, 2021 :
    Received in germany early in the morning.
    So far no system ui bugs anymore.
    Seems like performance and smoothness has increased also. No battery drain noticeable. 1628017257485.jpg
    Hopefully the update quality stays like this👍
    Antonygeorge99 likes this.
  2. Antonygeorge99
    Honeycomb Aug 3, 2021
  3. Antonygeorge99
  4. burnout123
    Ice Cream Sandwich Aug 3, 2021
    Yashdolas likes this.
  5. BAYOU Amine
    Donut Aug 3, 2021
    BAYOU Amine , Aug 3, 2021 :
    before/after screens or gtfo!
  6. Evgenij_
    Eclair Aug 3, 2021
    Battery life should stay nearly the same if you had no drain before. In case you had and update doesn't fix it, there are ways to analyze and fix them yourself.
  7. jmarks
  8. Louiscypher87
    Cupcake Aug 3, 2021
    Louiscypher87 , via OnePlus 8T , Aug 3, 2021 :
    I've updated with oxygen updater and my phone constantly booted up into recovery mode or whatever it was. I needed to input my password and had options to reboot or clear cache which I did and some other options, spent 4 hours checking how to unbrick my phone... Then I tried to press and hold both volume buttons and power button and got another options so selected start and it came back to life. Can someone explain me what was that please? Sorry I'm a new OnePlus user and never dealt with msm tools or upgrading or downgrading my android device in other way than ota.
  9. Evgenij_
    Eclair Aug 3, 2021
    It wasn't bricked, just booted into recovery for some reason. Would check the volume buttons operability first.
    Is the update installation finished? Newer Android devices have A/B partitions for seamless updates. Means if your system runs on A partition, the update would be installed to the B partition and vice versa. After a reboot the phone boots automatically to the new partition but you can end in recovery if it goes wrong too.
    Hard to say what happened without more information.
  10. Louiscypher87
    Cupcake Aug 3, 2021
    The update went ok I guess, it went to 100 % and asked me to reboot what I did, but after update it didn't boot up normally, showed up keyboard to Input password. There was a section called reboot reason or something like that and it said failed to int user if I remember correctly.
  11. Evgenij_
    Eclair Aug 4, 2021
    Evgenij_ , via OnePlus 8T , Aug 4, 2021 :
    Did you see this menu after entering key for decryption?
    Please go to settings -> about phone and verify the build number is 11.0.9.9..
  12. smallsmx3@gmail.
    Gingerbread Aug 4, 2021
    smallsmx3@gmail. , via OnePlus 8T , Aug 4, 2021 :
    Update is more fluid. Battery seems about the same. At least we're going in a positive direction. Downside is Android 12 is around the corner and we'll be starting over with a half baked rom for 8 months.
    SyamKG likes this.
  13. faizan_ahmad xyz
    faizan_ahmad xyz , via OnePlus 8T , Aug 4, 2021 :
    Do you guys get the option to share a file Via "Files go " ( google files ) from any gallery app. In OnePlus gallery or Google photos when we click share , we don't get the app listing of "files go " . Why
  14. Y1609576521836
    Donut Aug 4, 2021
  15. landov
  16. Louiscypher87
    Cupcake Aug 4, 2021
  17. Nikhil_Bhilai
    Honeycomb Aug 4, 2021
    Nikhil_Bhilai , via OnePlus 8T , Aug 4, 2021 :
    120hz on 8t triggers on its own even the phone sits on 60hz...what a crap OP has made 🖕🖕 who are the developers? Why they even get paid for developing such a crappy software?? 😡😡
  18. jmarks
    jmarks , Aug 4, 2021 :
    Olá,
    Alguém, em Portugal, recebeu esta atualização via OTA?
    Se sim, qual a versão que tinham antes da atualização?
    Cumps.
  19. SyamKG
    Ice Cream Sandwich Aug 4, 2021
    Loki10 likes this.
