241
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. A1600628851125
    Cupcake Oct 12, 2021
    trilogias and cmcdannold like this.
  2. Caomhin
    9 Series Expert, Participator of the Year Community Expert Oct 12, 2021
    Caomhin , via OnePlus 9 Pro , Oct 12, 2021 :
    That's True Caller website, strange that it wouldn't install. Maybe see what Trucaller say when they get back to you on your support ticket.
  3. Tom886
    Honeycomb Oct 12, 2021
    Tom886 , Oct 12, 2021 :
    Google, it's a requirement from Google. All data are still there, just new location. Move them to the new location as already written in this topic
    Everyone knows only 2 major updates and 1 year security updates. Not sure from where you got this knowledge
    Caomhin and Auristic like this.
  4. S1543561940152
    S1543561940152 , via OnePlus 6T , Oct 12, 2021 :
    After upgrading to OOS 11.1.1.1 on OnePlus 6T.....device seems slow,
    Many applications are crashing,I have huge contact list...which is crashing again nd again.
    Network drop issues increased.
    I have 90% of storage occupied, and upgrade from system update notification.
    Crashing issue is critical.
    cmcdannold and rgerardo like this.
  5. cmcdannold
    cmcdannold , via OnePlus 6 , Oct 12, 2021 :
    I disagree. Prior to the 11.x update, Gmail notification worked fine on my 6. However, since the update, I don't get any notifications from Gmail. The Gmail app itself had no update since the 11.x dropped.
  6. Nikhil_Rao
  7. Tom886
  8. Shanpeshwe
    Gingerbread Oct 12, 2021
  9. Tom886
    Another user in this topic had the same issue, something went wrong with a previous update or the file system got messed up. The only solution: Backup all your data, reset the phone and then install ur apps again. After that it is solved
  10. Tom886
    Did you provided the necessary log files to analyze the problems?
  11. p3y3ks
    Eclair Oct 12, 2021
    p3y3ks , via OnePlus 6 , Oct 12, 2021 :
    After 2 days of meshing up with whatsapp problem in OxygenOS 11.1.1.1, i've decided to do factory reset, which is i'm loosing for about 1 month un-backup whatsapp message and files...
    After factory reset, my OP 6 working well again..
    lesson learn from this case, next time OP do major upgrade like this (from Android 10 to Android 11) please do full backup before upgrading the OS, do factory reset after upgrade then restore the backup.. 🤣🤣🤣
  12. P1539594370758
    P1539594370758 , via OnePlus 6 , Oct 12, 2021 :
    I had some important info about 30 words saved as my alarm label, now in this new OS 11.1.1.1 those characters are no longer visible since upgrading to the new OS. It's displaying a maximum of around 8-9 words in the label. Any ways I can recover that data ?
    Pls help
  13. R1573409389898
    R1573409389898 , via OnePlus 6T , Oct 12, 2021 :
    Lot of bugs
    1. Call receiving late ,phone gets vibrate and rings but screen won't appear .
    2.Dam slow
    3.messages is like hell - msg will receive and it shows some thing .
    Lot of thins need to fix
    R1534451469747 likes this.
  14. B1578936738932
  15. C1582517723857
  16. Z1634050451286
    Z1634050451286 , via OnePlus 6 , Oct 12, 2021 :
    I have updated my android version from 10 to 11 yesterday. Since then facing a lot of issues.
    I am unable to send / receive images/docs in whatsapp. Error message is 'Download is unable to complete.Please try again'
    P.S i have ample space in my phone so this not a storage problem
    Also the images in the whatsapp are not accessible from the whatsapp app i need to see it from the folder in the file manager/ gallery.
    Unable to voice record in whatsapp.
    It's been more than 3 days and the issue has not been resolved
  17. aKilter
    Froyo Oct 12, 2021
    aKilter , Oct 12, 2021 :
    One thing seems perfectly clear about this "upgrade". It's an unmitigated disaster. This and the "Oppofication" of OnePlus makes it almost certain my next phone will be another brand.
    My wife and I both own OnePlus phones. She has a 6T and I have a 6T McLaren. The reasons we decided on OnePlus were: clean Android, good battery life, fast charging, large memory and storage at a very good price. We have been pleased with our phones and, until recently, thought our next phones would also be OnePlus.
    Both phones are about 3 years old now and we will both get new phones soon. We will both also get the same brand phone. It's just easier that way.
    The three phones we are considering: OnePlus 9, Google Pixel 6(about to be released) and iPhone 12. For various reasons, I won't even consider Samsung. Because of the reasons mentioned above, it seems our decision is now down to two. Unfortunately, OnePlus is doing everything it can to take themselves out of the running. It really is too bad.
    K1577555224305 likes this.
  18. StephCH
    StephCH , via OnePlus 6T , Oct 12, 2021 :
    For the first ever after years using OnePlus, I am sceptical about this last update. Since last update:
    The phone keeps switching to Edge network on its own and back to 4G after some time (in a city center).
    Battery that used to last a day and half now is only half a day 😔😭
    I love OnePlus for the way we are respected as customers and always providing the most for our product. Hope they are not moving to a well known marketing speciality of a famous American brand forcing customers to upgrade material.
    AniketM97 likes this.
  19. Caomhin
    Since installing OOS 11.1.1.1 on my 6T, the phone is functioning great, I cant find fault with it. Everything just works, no alterations had to be made. WhatsApp worked off the bat. I updated over 10.3.12, then over the initial 11.
    I understand others may have issues. And as 6T has more or less the same hardware with the exception of storage and ram maybe, mines got 6/128, its strange to see a few with such issues.
    Only thing I would suggest is to go with backing up your personal data and then do a clean full Erase All Data reset install, at least for 6T and maybe for 6 too. Don't restore the apps. But install them fresh. Maybe that might help many on here.
    Anyway, have fun with the faultless OOS 11.1.1.1 build release. 👍
  20. R1534451469747
