237
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. Jagadish Pyla
    Cupcake Oct 14, 2021
    Jagadish Pyla , via OnePlus 6 , Oct 14, 2021 :
    After updating to OxygenOS 11.1.1.1 facing slowness while using the apps, mobile is getting heated while charging and Whatsapp is not working properly unable to download the files or upload..I hope the issues will cleared fastly.
    Ibrahim433@ and DanielleD like this.
  2. bpdastoor
    bpdastoor , via OnePlus 6 , Oct 14, 2021 :
    Got the O2 11.1.1.1 update a few days ago. Most visible changes of any OS update so far I think.
    HOWEVER - my Google Photos is acting weird! VERY slow & NOT BACKING UP! Please help! Thanks.
  3. Aaron_hernandez
    DanielleD likes this.
  4. sangeeth_ajith
    sangeeth_ajith , via OnePlus 6T , Oct 14, 2021 :
    I have updated my device , it seems good , i was looking foreward for this update. But, it feel s very choppy and sometimes it fails to respond. And the bubble feature ie; the notification bubbles, that option isn't working.. does anyone how to activate that option??
  5. saurabhparmar03
    saurabhparmar03 , Oct 14, 2021 :
    After the update my whatsapp stopped working.
    Not able to send or receive any media.
    First i thought this error was from whatsapp side, but the same whatsapp version is working fine on samsung phone.
    Whatsapp version: 2.21.21.9(Beta)
  6. A1634196104765
    A1634196104765 , via OnePlus 6T , Oct 14, 2021 :
    Bonjour, j'ai un OP 6T qui fonctionnait très bien jusqu'à la dernière mise à jour avec la version 11.1.1.1.
    Je n'ai plus accès à mes données. Ce n'est pas ma carte SIM le problème.
    Avez-vous une solution? Merci!
  7. Auristic
    Lollipop Oct 14, 2021
    ItsRavi25 likes this.
  8. swsr
    swsr , via OnePlus 6T , Oct 14, 2021 :
    After updating, my OnePlus 6T has got an Horizon Light option in Customisation. Did anyone else get it? And though there is the option i don't think it's working as the horizon lights haven't lit up once till now.
  9. P1539521495341
  10. Tom886
    Honeycomb Oct 14, 2021
    Tom886 , Oct 14, 2021 :
    Nope, you didn't read all comments, otherwise you would have found my post, stating that a standard filemanager cannot access the Android\Data folder.
    Either you must be rooted with root access to this folder, or connect your mobile to a PC/Notebook and you see the content of this folder.
    Auristic likes this.
  11. popxunga
    Eclair Oct 14, 2021
    popxunga , via OnePlus 6T , Oct 14, 2021 :
    That's the way it works I think; it lits once the notification occurs and then stops which makes what could be a very useful feature just useless IMHO.
  12. sHrIkANT_Shende
    Donut Oct 14, 2021
  13. Auristic
    Auristic , via OnePlus Community App , Oct 14, 2021 :
    6 Series will never get either A12 or ColorOS integration.
    Not talking about custom ROMs.
  14. Z1582746812079
    Z1582746812079 , via OnePlus 6 , Oct 14, 2021 :
    This if by far the worst update ever. since you have mentioned battery optimization but after the update batter drops sooner than my previous version. The new UI changed everything that looks like a traditional oneplus which is not looking good. I wish i could go back to my previous version
    swsr likes this.
  15. Auristic
  16. rahul_karwa
    Froyo Oct 14, 2021
    rahul_karwa , via OnePlus 7 Pro , Oct 14, 2021 :
    Same issue I am facing.
  17. guisbro
    Ice Cream Sandwich Oct 14, 2021
    guisbro , Oct 14, 2021 :
    I generally top up from about 50% to 100%, which apparently isn't recommended for battery life. After 3 years I expected the battery life to have deteriorated, so I did a check dropping from 100% to 2% over a fairly heavy usage of 22 hours and got just over 9 hours SOT. I would probably have got 10 hours SOT when it was new so I'm fairly happy with battery and Android 11.
  18. Auristic
  19. V1577201881877
    Donut Oct 14, 2021
  20. Andreas Rauchhaus
    Eclair Oct 14, 2021
    Andreas Rauchhaus , via OnePlus 6T , Oct 14, 2021 :
    Some days later it seams that battery consumption is more than it was on Android 10. Especially when the phone uses mobile LTE network during the day. But it still gets me through the whole workday.
    When the phone uses a WLAN in the evening at home you can figure out, that battery consumption flattens. So my battery lasts much longer when in WLAN connection.
    All apps are still working fine. Didn't get any problems with them yet.
