235
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. Maylincharaba
    Cupcake Oct 16, 2021
    Maylincharaba , Oct 16, 2021 :
    I can't use cell data after the update , contact 1Plus , was told they were on it , any idea when is this gonna get fixed ?
    It sucks without cell data especially I am still paying for it
  2. Matthousef1
    Matthousef1 , via OnePlus 6T , Oct 16, 2021 :
    Updated to 11.1.1.1, I am reasonable happy about the update, did a factory reset and no major problems so far..but the mesh wifi bug is still there and that is really annoying..tried also resetting the wifi, Bluetooth, network settings, still no luck..when is Google/OP ever going to fix this?
  3. ProfessorG
    Froyo Oct 16, 2021
    ProfessorG , via OnePlus 6T , Oct 16, 2021 :
    I did not reply to you .So I am glad that the language was not speakable for you. 🙂
    maan1996 likes this.
  4. Auristic
    Lollipop Oct 16, 2021
    ItsRavi25 likes this.
  5. vinitshriyan
    vinitshriyan , via OnePlus 6T , Oct 16, 2021 :
    Received this update last week and effective today my phone voice output stopped working. Can hear the callers voice only when the speaker is turned ON or hands free is used. Tried restarting the phone, booted phone on safe mode and lastly reset the phone with factory settings. Issue is still not resolved. Does anyone have a quick fix.
  6. J1634023297585
  7. devendrasanghavi
    devendrasanghavi , Oct 16, 2021 :
    Is anyone facing an issue with text/sms messages? I have started to miss incoming and outgoing messages after taking this update. Both Text and MMS messages. Using the native Android Messages app. Thanks.
  8. JosianeM
    JosianeM , Oct 16, 2021 :
    Hello, after this update I am no longer able to connect to my cell data through Koodo. I have spent the last three hours on the phone with koodo and on support with oneplus. Koodo says it is from the update...please someone fix this! There is nothing I can do on my end, it seems to be due to APN errors which I cannot fix. I now have a basically useless phone.
  9. shivin90
    Donut Oct 16, 2021
  10. Ahad0124 , via OnePlus 6T Midnight Black , Oct 16, 2021 :
    After upgrading most of the time found touch latency and also lag during many apps and most of the time was wile getting into the menu it's really disappointing. I was more happy with my last stable version this one ruined my hopes regarding OnePlus. Also facing heating issue while playing games and charging.
  11. M1634384651782
  12. K1633888200975
  13. Trugo
    Trugo , Oct 16, 2021 :
    3200 complaints but they didn't take the time to read or do what they are supposed to do. My phone works perfectly, I am on OS11.1.1.1, I update from beta3 accordingly, restarting and reinstalling everything from 0. The battery lasts all day (it is the original that came in the phone), the applications open as fast as always and the games the same. Faced with any problem, 1+ is accused but does not take into account that at some point you have to reinstall from the beginning, android 11 means many internal changes and they are not the responsibility of 1+. To those who want to go to Iphone, good luck and never drop it, know that Apple does not sell spare parts and does not repair any phone anywhere in the world.
    Cheers
    Pinttas likes this.
  14. KHALID ALSULAIMAN
    Pinttas likes this.
  15. Koushik87
    Gingerbread Oct 16, 2021
    Koushik87 , via OnePlus 6T , Oct 16, 2021 :
    You have to understand not every hardware behaves the same way. Some are lucky and some are not. So stop pretending yourself as genius and other 3199 as idiots who would spam the forum. Go to XDA and find the feedbacks on 11.1.1.1 yourself. Good luck OP might soon hire your for being so positive to them. By the way I am among those unlucky 3199. Forum is for a reason, respect everyone s opinion and stop fooling around self proclaimed genious.
    GauravaRai and maan1996 like this.
  16. tushar2014
    Cupcake Oct 17, 2021
    tushar2014 , via OnePlus 6 , Oct 17, 2021 :
    I got the Android 11 update on my Oneplus 6 today, which I followed through with. After the update, WhatsApp has been giving all sorts of issues with regards to storage. No files (images, videos, audio, documents etc) are getting downloaded or getting sent. The images received before the update are getting seen but the ones sent are not visible. This is observed while all the permissions are enabled for the app. The compression of the images is happening, as observed by trying to send a 4 MB image to see it fail as a 160 KB image with the message "this file does not exist on your internal storage".
    Things tried till now to solve the issue: said:
    Phone reboot
    Force Stop WhatsApp and restart the app
    Force Stop and Clear Cache and then restart the app
    Move an image physically to the sent images folder of WhatsApp and then try sending it
    Remove File storage permissions and then try downloading - got prompted asking for permission which I gave and then the same failure of "the image cannot be downloaded"
    Creating a local backup (for reinstall purposes) - failed again as can not write to local
    Messages and calls are going all fine while all this and the issue is just with the files.
    Rishi Pratap and J1634390664943 like this.
  17. PascalB78
    Donut Oct 17, 2021
    PascalB78 , Oct 17, 2021 :
    3 hours with Koodo and they couldn't fix it ?? wow they are bad !! My wife had this issue and I solved it ... you just need to add the Koodo APN manually... why Koodo couldn't help you with this ?? Call them again, they should be able to help you
    Auristic likes this.
  18. Tom886
    Honeycomb Oct 17, 2021
    Tom886 , Oct 17, 2021 :
    Try to clean the USB Port, you won't believe how much dirt it collects after a while.
    Cheers
  19. N1545652617699
    Donut Oct 17, 2021
    N1545652617699 , via OnePlus 6T , Oct 17, 2021 :
    Calling is also an issue. Not able to connect calls. And the proximity sensor which turns off the screen light when bringing it closer to ear is also not working.
    Phone freezes and restart while watching youtube videos.
    Battery backup is got worsen with this update.
    Pls fix all these.
  20. J1634390664943
    J1634390664943 , via OnePlus 6T , Oct 17, 2021 :
    my device is o
    ne plus 6t. yesterday i have updated my os to oxygen 11.1.1.1 and after that my whatsapp is not working.below are the issues i am facing
    1. unable to download any media.it shows the download was unable to complete please try again later.
    2. all media and voice notes are been deleted and when clicking it shows sorry this media file seems to be missing
    3. unable to open any status. it shows the same message as first.
    i am attaching screenshot of all the issues. please help me in resolving these major issues.i am stucked badly. didn't expected such bad behaviour after updating os.
    note - i have tried both from wifi and mobile data.
    one plus team please try to connect with me and provide me the solution
