238
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. juneds
    Cupcake Oct 17, 2021
  2. J1634390664943
    J1634390664943 , via OnePlus 6T , Oct 17, 2021 :
    Hi
    I am also facing same issues one my one plus 6t device
  3. cyberman_5145
    Honeycomb Oct 17, 2021
    cyberman_5145 , via OnePlus 7 Pro , Oct 17, 2021 :
    So basically in simple terms MSM tool is a utility that the service center use to downgrade your device to official factory OS built when we don't see an official rollback package to install and downgrade. It's 100% safe as I have used it myself several times.
    What you should research about before using it is, how to enter into EDL mode on your device.
    Though it's way too simple and has key combination to press and hold for approx 20 seconds.
    DO NOT CONNECT YOUR DEVICE USING DATA CABLE amd perform these steps exactly how they are sequenced below.
    1. Switch off your device and allow it 10 seconds when screen goes off.
    2. Press only volume up & down jeeya at the same time and hold on to the keys for 20 seconds.
    3. Run the MSM downloader Tool.
    4. Connect the device to your laptop / desktop running MSM tool.
    Once you see the status as connected in MSM tool, hit the start button and allow the process to complete which usually takes upto 5 mins.
    Once the device boots up, you will be back to official version of OOS for your device depending upon which OOS version you downloaded the MSM tool package for.
    Hope this helps.!!
    toni78 likes this.
  4. GaneshKunte
    GaneshKunte , Oct 17, 2021 :
    Screen won't turn off automatically sometimes, even though I have set it to 15 seconds.
  5. Trugo
    Trugo , Oct 17, 2021 :
    My opinion is that you did not understand anything, genius.
    As it is said elsewhere, problems are only published because those who say they do not have them are attacked, it is only my opinion. And I am sorry you were not as lucky with your OP as I was having acquired my second hand OP6.
    Better luck for the next one.
  6. Lopez4Peepz
    Donut Oct 17, 2021
    Lopez4Peepz , Oct 17, 2021 :
    My settings are all merked. Will have to try and sort them out once i am home for a few days from working. Colors wonky, home screen grid layout changed, fonts are gross. gg
  7. Koushik87
    Gingerbread Oct 17, 2021
    Koushik87 , via OnePlus 6T , Oct 17, 2021 :
    If you don't have a problem with yours enjoy but dont comment without understanding other's issues. A basic incremental update can break so many things if not properly tested and this A11 is a major leap. And regarding attacking, I think you didn't get the context. If something is not right its better not to assume things without facing it yourself. I reverted to 11.0.0.0 coz of the issues in 11.1.1.1, its takes time and effort to do so. A word of caution to others with help them to save time from downloading such half baked update and running into trouble. Cheers.
    G1634021987649 likes this.
  8. shivin90
    Donut Oct 17, 2021
  9. Ni7547
    Froyo Oct 17, 2021
    Pinttas likes this.
  10. ParthJadhav_7
    ParthJadhav_7 , via OnePlus 6 , Oct 17, 2021 :
    The worst update till date. My whole device has started lagging , multitasking is gone to dust the device hangs on opening just 2-3 apps. Battery drainage is severe , the phone seems to have slowed down on purpose 😑.
    Fix this ASAP.
  11. Rishi Pratap
    Eclair Oct 17, 2021
    Rishi Pratap , via OnePlus 6 , Oct 17, 2021 :
    I am facing a lot of issues after update which were not there before:
    1. Music apps playback vanishes and music pauses from locked screen after 1 min
    2. Camera app crashes and is slower now
    3. Screen flickering sometimes
    4. Whatsapp media not showing in whatsapp
    Is anyone else also facing these and any resolutions?
    ParthJadhav_7 likes this.
  12. N1634280748999
  13. ParthJadhav_7
    Whatsapp media is not showing because after the update the whole folder of whatsapp has been shifted outside , and a newer folder is created automatically. Such pathetic unstable update.
    Backup all your important pics clips and data. It's corrupting slowly 😑😐 , dunno how....
    Rishi Pratap likes this.
  14. Y1619888250061
    Y1619888250061 , via OnePlus 6 , Oct 17, 2021 :
    I am facing Screen flickering problem in my Device I have done many factory reset but no solution
  15. U1592243413238 likes this.
  16. lgaddipall
    lgaddipall , via OnePlus 6 , Oct 17, 2021 :
    After recent Android 11 update , missing media on WhatsApp. So many important images , documents missing. OnePlus should look into this on priority. I have tried all suggested solutions but nothing seems working for me. Kindly help with resolution. Thanks 🙏
    [email protected] likes this.
  17. K1577555224305
    K1577555224305 , Oct 17, 2021 :
    Yes, it is very irritating. For colors you can change from Setting - displAy - screen calibration - Advanced (3 options ) , Natural or Vivid, which ever suits you.
    Lopez4Peepz likes this.
  18. Auristic
    Lollipop Oct 17, 2021
    mrcgomes, ItsRavi25 and ironass like this.
  19. Vivek_Kumar...
    Donut Oct 17, 2021
  20. X1577504315188
    X1577504315188 , via OnePlus 6 , Oct 17, 2021 :
    Hi Team after update of 11.1.1.1 , system not stable , I m facing below issues.
    1. Wifi connectivity issue
    2. Bluetooth connectivity issue
    3.Moble heating issue
    4. Apps are crashing frequently
    5.Batter drying fast.
    6 there is also fluctuations in screen light .
    I am not if you guys give update to stable the system or put us in to trouble.
    Is you B team is working on updates , it's really sucks
