238
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. Koushik87
    Gingerbread Oct 19, 2021
    Koushik87 , via OnePlus 6T , Oct 19, 2021 :
    Please check the package size is over 2 GB. Incremental package might face error if you skipped 11.0.0.0. Also download 11.0.0.0(A11 with higher security patch then 10.3.12) and try doing a local upgrade. If it installs then it can be possible that 11.1.1.1 package got corrupted somehow, do a fresh download of it and try again.
    Didier PARENTI and Auristic like this.
  2. Pinttas
    Honeycomb Oct 19, 2021
    Pinttas , Oct 19, 2021 :
    Just to share with you that not everyone has bugs. I regret that a lot of people have it and I hope it is possible to correct it.
    My battery backup
    I'm not a heavy player but sometimes I play something.
    If I don't make intensive use of the phone, the battery lasts for a day and a half or two.
    My benchmarks. Not the best but not de worse.
    Respect
    jasonanouk, karaj_h35 and Auristic like this.
  3. vincent.sochard
    Cupcake Oct 19, 2021
    vincent.sochard , via OnePlus 6T , Oct 19, 2021 :
    Hi, when disabling the Bluetooth absolute volume, all my speakers are starting at CRAZY HIGH volume. (disabling this option is supposed to do exactly the opposite!!). Please fix it ☺️ 🙏 Thanks a lot
  4. Sailor.Nepal
    Donut Oct 19, 2021
    Q1548174222232 and Lopez4Peepz like this.
  5. Y1634662861014
    Lopez4Peepz likes this.
  6. V1634647465742
    V1634647465742 , via OnePlus 6 , Oct 19, 2021 :
    I just updated to the new OS, after that i am unable to send / receive any media files on whatsapp.
    It is even not opening my mobile camera in chat..
    Kindly someone help/guide.
  7. Lopez4Peepz
    Donut Oct 19, 2021
    Lopez4Peepz , via OnePlus 6T , Oct 19, 2021 :
    Very much agree. This is such a horrible update, I'm just going to get another brand phone and use that. I'll keep the 6T for other uses. 11.1.1.1 put me over the edge with the level of hot garbage it is.
  8. P1633038158201
    P1633038158201 , Oct 19, 2021 :
    ever since this update downloaded, I have no mobile data. I've used another phone since but want to fix this. Using Koodo in Canada.
  9. Samrin_Khan
    Samrin_Khan , via OnePlus 6T , Oct 19, 2021 :
    This update is draining out battery quickly.
    Before this I had superb battery back up for more than 24hours in 1 charge
    Also phone gets stuck quite often especially gallery is messed up!!!!
    Please fix this soon !!!!!
  10. F1616848969897
    Donut Oct 19, 2021
    G1634021987649 likes this.
  11. F1616848969897
    Donut Oct 19, 2021
  12. P1633038158201
    never mind...found settings on web and it works !
    Tom886 likes this.
  13. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 20, 2021
    Artemus , Oct 20, 2021 :
    Back up your data and perform a factory reset. Don't restore apps, redownload them manually after setup.
    Auristic likes this.
  14. J1634696425943
    Cupcake Oct 20, 2021
  15. Artemus
    The calls/texts thing might be carrier-related, seems Verizon is hit the most. As for the military time, go to Settings > System > Date & time > enable then disable "Use 24-hour format".
  16. J1634696425943
    J1634696425943 , via OnePlus 6T , Oct 20, 2021 :
    No problem with the carrier, I use ATT. The time seems to be fixed.
  17. zanyguy
    zanyguy , Oct 20, 2021 :
    I have just now installed the latest update 11.1.1.1 and my oneplus launcher has stopped working. Tried solutions found online but none are working (webview, etc.). The screen keeps flickering at start and I am able to access my apps only through the notification window! Any solution for this??
  18. Tom886
    Honeycomb Oct 20, 2021
    Tom886 , Oct 20, 2021 :
    Delete cache and data from the launcher, but be prepared that you have to setup ur desktop with the shortcuts again.
    Cheers
  19. Rishi Pratap
    Eclair Oct 20, 2021
    Rishi Pratap , via OnePlus 6 , Oct 20, 2021 :
    Solved one of the issues of playback in music apps stopping /crashing after locking screen. The apps need to be switched back from optimized setting to intelligent control. Hope this helps.
