238
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. T1563077126290
    Cupcake Oct 27, 2021
    T1563077126290 , via OnePlus 6T , Oct 27, 2021 :
    I have a 6t, since the last update here are the issues I've been facing:
    -Consuming so much more battery, even though I'm not using my phone a lot
    -Taking awhile to increase or decrease the screen brightness
    -Much slower and apps are not functioning correctly or freeze.
    -Delay in placing calls or not going through
    -I use screenshots a lot and for me it was much easier to press the power button and select screenshot with just my thumb, please bring back this feature. Now I have to press the power button and the decrease volume buttons at the same time.
  2. Lyfsbttrwithacat13
    Eclair Oct 27, 2021
  3. I1541007515863
    Froyo Oct 27, 2021
    I1541007515863 , via OnePlus 6 , Oct 27, 2021 :
    3 finger screen shot is much more easier than to press power button 🙄
  4. B1633893270561
    B1633893270561 , via OnePlus 6 , Oct 27, 2021 :
    Hi after upgrate to 11.1.1.1 in all applications that use camera the camera stop working . The main camera works ok. I try to change settings application to allow camera also try to delete cash and even to remove and install again but noothing help.
    When you're going to fix those bugs ? Can I downgrade it?
  5. MirzaAswad
    Eclair Oct 27, 2021
  6. Koushik87
    Gingerbread Oct 27, 2021
    Koushik87 , via OnePlus 6T , Oct 27, 2021 :
    First off all you will have to unlock bootloader and get a custom recovery like TWRP. Evolution X is separate rom itself with all features from OOS plus many more customisation than OOS. There are many more roms out there that you can try once you have a custom recovery. Since oneplus is not going to provide any further major Android update for 6 series, and you want a taste of A12 or future versions custom roms are the way to go.
    Regarding security yes, unlocking bootloader compromise security thats why you have to have magisk to keep ur integrity intact and apps from detection of root. It's worth a shot if you like to try better roms, but if you are sceptical on security suggest you do some research and take a call. Visit XDA and you get to know. said:
    There are no down sides only positives.
    Forget to mention, once you unlock bootloader tou will loose all data. So do full backup before you proceed.
  7. M1635305660911
  8. kaushaljoshi
    kaushaljoshi , via OnePlus 6 , Oct 27, 2021 :
    The update has lot of bugs and problems. Can't use phone while charging, the screen is dark .Had to reset my phone. Charging problem still there. Only two font choices and that too are pathetic.
  9. Darokar
    Darokar , via OnePlus 6 , Oct 27, 2021 :
    Extreme fast battery drain on this update !!!!!!!! Dont install this..... And all aplicaction work much worst even google chrome shows white screen on search .....😭
    Lopez4Peepz likes this.
  10. Tom886
    Honeycomb Oct 27, 2021
    Tom886 , Oct 27, 2021 :
    Which bug? Do you refer to Absolute Volume? Maybe being more detailed about that, would be helpful.
    D.Sai Suhail Baba likes this.
  11. Tom886
    Have you tried to delete data and cache from for Package Installer in App Info after enabling "Show System"?
  12. Winglet97
    Winglet97 , via OnePlus 6T , Oct 27, 2021 :
    Basically ,even I turn off the autosync volume in earphone mode and in developer option.sometime the phone will still sync the Bluetooth volume.only happening on the latest firmware version
  13. rkane21
    rkane21 , Oct 27, 2021 :
    Thought I resolved my 6T with not receiving SMS messages. Well. Just found that hasn't been working for about a week again after I swapped sim card trays, Slot 1 does NOT work with calling or SMS at all... Android can finally automatically find the network for SIM 1 but communications does not work.. COME ON OnePlus, this is STUPID. At least show something on your website that this is a known issue...
  14. Tom886
    Strange, I disabled Absolute Volume, but even that I can always control Volume by my earphones, worked always, also in previous Android versions. Are you sure that's not by design?
  15. Tom886
    For acknowledging that this is a known issue, did you provide the logs to OnePlus that they can figure out what could be the root cause. FYI, it could be also your network provider, and I haven't seen that everyone experienced that problem. Known issue is defined as, that the Hardware provider can duplicate this issue, but for this they need access to the above mentioned logs and more background information; also under which conditions.
    D.Sai Suhail Baba and rkane21 like this.
  16. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 27, 2021
    Caomhin , via OnePlus 9 Pro , Oct 27, 2021 :
    You may want to consider Backing up your phone data and then do a full Erase All Data factory reset to refresh your current installation of OOS 11.1.1.1
    Clear the Camera App info Cache and App info Storage.
    Also Clear the OnePlus Camera Service App info Cache and App info Storage as well.
    Restart the phone. Check if this can help.
    If still mot working, you might want to consider trying a reset as per above suggestion.
    If you still want to downgrade here are the details.
    ROLL-BACK FROM CURRENT ANDROID 10 OR 11 TO EARLIER STOCK ANDROID 9 OR 10
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    Thanks to @ironass for putting this together and maintaining the thread.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    rgerardo, Auristic, rhyd1am and 2 others like this.
  17. V1560005724730
  18. Caomhin
    Contact your Mobile Network provider to ensure their APN settings match your APN settings on the phone.
    Auristic and D.Sai Suhail Baba like this.
  19. V1560005724730
    V1560005724730 , via OnePlus 6 , Oct 27, 2021 :
    Mobile network is not stable. If I change my settings from 4g to 2g than I can call only. But on incoming calls. But before the update it was fine I use full 4g network.
