241
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. Caomhin
    9 Series Expert, Participator of the Year Community Expert Oct 27, 2021
    Caomhin , via OnePlus 9 Pro , Oct 27, 2021 :
    Who is your Network provider, simply asking as some users on US networks with 11 on 6 Series have had similar issues.
  2. António Pedro Santos
    Froyo Oct 27, 2021
    Akshat2793 likes this.
  3. Lemonfleck73
    Jelly Bean Oct 27, 2021
    Lemonfleck73 , via OnePlus 6 , Oct 27, 2021 :
    install Havok OS and you think you have a new phone...lol 😁😁😁
  4. António Pedro Santos
    Froyo Oct 27, 2021
    António Pedro Santos , Oct 27, 2021 :
    exactly, with LineageOs on my OP 6 I had the same feeling. 😁
    D.Sai Suhail Baba likes this.
  5. mrcgomes
    Cupcake Oct 27, 2021
  6. anil2512
  7. Caomhin
    Auristic and rhyd1am like this.
  8. anil2512
  9. Caomhin
    Have you reset the App permissions as suggested in the links I gave, also set a different sound in the WhatsApp or try the same notification sound used for SMS app and see if that works.
    Auristic, rhyd1am and anil2512 like this.
  10. anil2512
    anil2512 , via OnePlus 6T , Oct 27, 2021 :
    Done. First i change notification different tone.then all whats up permission denied .and then open whats up.its working.step by step permission allowed. thanks a lot
    rhyd1am and Caomhin like this.
  11. Caomhin
    Just so I am not misreading it. It does work now, is that correct. If so happy days 👍
  12. Avadhoot...
  13. Avadhoot...
  14. Caomhin
    Yes
    Did you update to this 11.1.1.1 in between the 2 posts above, 1 minute apart. Because you have to give the new update time to settle in, generally at least 1 full charge cycle, but 2 full charge cycles would be better.
    Auristic and ironass like this.
  15. Avadhoot...
    Avadhoot... , via OnePlus 6 , Oct 27, 2021 :
    I have already updated to android 11.1.1.1 and major issue is battery draining and camera lagging since last 10 days
  16. Caomhin
    You might want to consider backing up the phone and doing a full Erase All Data factory reset to refresh your current installation of OOS 11.1.1.1 on the phone.
    Auristic likes this.
  17. Avadhoot...
    After factory reset this android version work properly like android 10??
  18. bhivesh
    bhivesh , via OnePlus 6T , Oct 27, 2021 :
    Whatsapp application issue ( unable to download or upload or read any media)
    Call delay
    Gmail Notification
    No network stability even when connected to hight speed wifi
    Worst update.. phone is totally messed up.. unable to use
  19. Caomhin
    Some say it did, others say it fixed some issues but not all. Your results may differ.
    Try reinstalling and don't restore anything. To see how it fares out. Install the apps you want individually. Sometimes a restore may place old app data back on the system and can create its own issues again. Worth a try without restoring apps. See how it works out for you.
  20. Caomhin
    If you read the many solutions posted further up this thread for your issues, you will find some are an easy fix. In the WhatsApp case, that is WhatsApp fault for moving their folders to suit Android 11.
