241
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. pennxu
    Cupcake Oct 28, 2021
    pennxu , Oct 28, 2021 :
    After the upgrade, it is not compatible with my SIM card. I can make calls but cannot use mobile data. There is no problem in version 10.3.12, my service provider is CMLink.
    I have to go back to 10.3.12☹️
  2. BEINGSHREY
    Donut Oct 28, 2021
    BEINGSHREY , via OnePlus 6T , Oct 28, 2021 :
    OOS10 was Perfectly Stable yes! Not just at starting stage, it was completely stable until next update
    kãräñ_90564 likes this.
  3. mkirit
    mkirit , via OnePlus 6 , Oct 28, 2021 :
    Whatsapp images videos n all media files have gone after this update 11 on my one plus 6. No solution in sight. As i read many are facing the same problem
    bhivesh likes this.
  4. J1541530623924
    J1541530623924 , via OnePlus 6T , Oct 28, 2021 :
    I like the new update, especially that I can directly use the canvas function.
    But my problem is since I made the update I often (not always) got the message that my camera is used by another app. Not only in Apps, even for Face unlock.
    And I don't think I got an virus, which of course could cause the same problems, because it started on the day I installed the update.
  5. TheDarkTron
    TheDarkTron , Oct 28, 2021 :
    Hi there! I have severe problems after updating to 11.1.1.1:
    Every morning networking is broken. The WiFi can connect, but it says "No Internet" I have a 5GHz Router with WiFi 6 and WPA3. Mobile data is broken too. I have signal but the icon has this little "!" next to it and no connection to the internet can be made.
    I noticed this every time I wake up in the morning and I am pulling the phone from the charger. I charge my phone over night.
    The issues resolve after rebooting the device.
  6. Caomhin
    9 Series Expert, Participator of the Year Community Expert Oct 28, 2021
    Caomhin , via OnePlus 9 Pro , Oct 28, 2021 :
    If you search for WhatsApp in the Community you will find the answer. Solution has been mentioned many times in sight.
    WhatsApp has changed the path where to save images, videos, GIFs, audio, documents and stickers on WhatsApp for Android.
    Step 1
    https://wabetainfo.com/how-to-fix-missing-media-on-whatsapp-for-android/
    Step 2
    https://wabetainfo.com/how-to-restore-the-media-visibility-on-whatsapp-for-android/
  7. SpeedBaracuda
    SpeedBaracuda , Oct 28, 2021 :
    since the update of my 6t my camera don't works regularly i have to restart the smartphone once a day. Face Unlock also no longer works reliably. What can i do?
  8. Caomhin
    Android 11 has more security than 10 did, and it is now informing you that some apps may have permission and are using the camera. If you don't want to give that permission you would have to revoke it within the app info of the App itself.
    Also try the following as well.
    Clear the Camera App info Cache and App info Storage.
    Also Clear the OnePlus Camera Service App info Cache and App info Storage as well.
    Restart the phone. Check if this can help.
  9. Caomhin
    Reset your Network adapters, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also try the following. If the option is available to you.
    Go to Settings, WiFi & Internet, WiFi, WiFi Preferences and disable Intelligently Select the best WiFi.
    Also check out additional possible solutions at the link below.
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android/
    Auristic and D.Sai Suhail Baba like this.
  10. Caomhin
    Check the post below yours on how to clear the Camera and Camera Service Cache.
  11. Caomhin
    Check the post above yours about removing and creating a new APN. This might fix your Mobile Network data issue
  12. Bayuputra4 , via OnePlus 6T Midnight Black , Oct 28, 2021 :
    Pliiss help fix this problem, this very suck and anoying this happen every time in a day, this never happen on android 10, after android 11 OOS 11.1111 this nightmare come, come on oneplus fix this iam preety sure this is software issue
  13. Caomhin
    Do a search for Qualcomm Crashdump. This can sometimes be software issues and other times hardware. There are many posts where people have resolved the issue and others that required a visit to a OnePlus Approved Service centre. It's a bit of a mixed bag as to why it happens.
  14. Phanilkumar
    Gingerbread Oct 28, 2021
  15. W1539505948164
    Donut Oct 28, 2021
    W1539505948164 , via OnePlus 6 , Oct 28, 2021 :
    Help whatsapp media divided between two folders after update
    Not able to see old media in Whatsapp after update
    Can someone help in this issue.
    Battery drain is real
    I am unable to understand why this has happened
    One plus updates were always great don't know about this one though.
  16. Caomhin
    Suggested WhatsApp fix posted today 9 posts up ⬆️ from yours
    Auristic and ironass like this.
  17. Tom886
    Honeycomb Oct 28, 2021
    Tom886 , Oct 28, 2021 :
    Try to disable WPA3, OP6T should support it, but there maybe is an issue. I have also WiFi 6 at home, but use WPA 2
    Auristic and Caomhin like this.
  18. czaravi
    czaravi , via OnePlus 6T , Oct 28, 2021 :
    After the latest update there seems to be some issues with the pocket mode sensor and the screen blacks out for no reason at all.... anyone facing similar problems?
  19. Caomhin
    If you have a case on the phone, remove it and see if it still happens. It may be that OOS 11.1.1.1 may have changed the sensitivity of the sensor.
    czaravi and Auristic like this.
  20. X1598025095825
    X1598025095825 , via OnePlus 6T , Oct 28, 2021 :
    With latest update of software in mid October, 2021, my phone 6T is giving trouble in battery backup. My usage is almost same but battery is draining almost double speed.
    My phone is 2.5 year old
    Pls look into the matter
    C1635416822089 and Barosh like this.
