242
OxygenOS 11.1.1.1 for the OnePlus 6 and OnePlus 6T
  1. trilogias
    Donut Dec 3, 2021
    trilogias , Dec 3, 2021 :
    Not fixed for me
  2. trilogias
    Donut Dec 3, 2021
    I updated 24 hours ago. Gmail notifications were not working at first. Since this morning if they worked until several hours ago.
  3. A1594910915738
    Honeycomb Dec 3, 2021
    A1594910915738 , Dec 3, 2021 :
    Serious, so it's not fixed??? So they stop again at synching after a few hours? Ok then we are screwed, then a proper fix will never come and we are forced to use a custom ROM :-(
  4. Matthousef1
    Cupcake Dec 3, 2021
  5. A1594910915738
    And you had issues before on 11.1.1?
  6. Matthousef1
    Cupcake Dec 3, 2021
    Matthousef1 , via OnePlus 6T , Dec 3, 2021 :
    Yes, installed 11.1.1.1 about 4 times, had only the frkng annoying Gmail issue, now for 24 hours all good. I installed 11.1.2.2 over 11.1.1.1, dirty install.
  7. A1594910915738
    Ok, sound promising.. did you have other issues too on 11.1 and now fixed on 11.2 , like camera and battery drain?
  8. Matthousef1
    Cupcake Dec 3, 2021
    Camera was never a problem for me, battery drain was there also in 11.1.2.2, but it settled after some hours, now it's much better after a day..you have to give it a bit time. I did no wiping of cache yet
  9. A1594910915738
    Cool, thnx for feedback
  10. Royal_RJ
    Ice Cream Sandwich Dec 4, 2021
  11. E1638806248972
    Cupcake Dec 6, 2021
    E1638806248972 , Dec 6, 2021 :
    My OnePlus 6T received the Android 11 update, but unfortunately, I have two major problems. I was wondering if OnePlus plans to address the issues. Releasing a major software update 1 month from being out of support is not really a good practice. Introduced bugs should be addressed. The two major problems are:
    • bluetooth is now not working reliably, devices keeps disconnecting. Pretty much it cannot be used. This happens with all devices connected.
    • Some apps are detecting running as a rooted device, of course, I am not rooted.
    Thanks....
  12. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 6, 2021
    Caomhin , via OnePlus 9 Pro , Dec 6, 2021 :
    For Bluetooth try the following to see if it helps.
    Reset your Bluetooth adapter.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    And also Disable "Sleep Standby Optimisation " in the
    Settings, Battery, Battery Optimisation, 3 dots menu top right, Sleep standby optimisation.
    Re-start your device.
    Check if this can help.
    Not sure why those apps are detecting phone as rooted. But check the Google Play certification in Google Playstore, Settings, About, Play Certification.
  13. Y1545475127587
    Cupcake Dec 8, 2021
    Y1545475127587 , via OnePlus 6 , Dec 8, 2021 :
    I have submitted all the information requested for this bug, but the update did not fix it.
  14. S1639063215245
    Cupcake Dec 9, 2021
    S1639063215245 , via OnePlus 6 , Dec 9, 2021 :
    Newest update made my phone internet unstable, won't stay in 4g. Doubt this will get fixed since it's the EOL of this phone model. I believe after all the research and time trying to fix it, that this was done on purpose to push people with older phone to buy new. Nothing was wrong with my phone prier to installing this new update.
  15. K1577555224305
    Ice Cream Sandwich Dec 9, 2021
    rhyd1am likes this.
  16. rhyd1am
    KitKat Community Expert Dec 9, 2021
    rhyd1am , Dec 9, 2021 :
    All working fine on my 6T, which somewhat end that theory 🙂
    Try the suggestion already given.
    S1639063215245 and Caomhin like this.
  17. Mohammeddk
    Donut Dec 10, 2021
    Mohammeddk , via OnePlus 6 , Dec 10, 2021 :
    Worst experience with new update
    Battery draining fast
    Late call notification
    Phone lagging
    If i play game then it totally hang
    Plz provide new stable version
  18. K1577555224305
    Ice Cream Sandwich Dec 11, 2021
    K1577555224305 , Dec 11, 2021 :
    Wair for further uodate of 11.1.2.2 .. idk but lets hope it fixes.
  19. S1639063215245
    Cupcake Dec 11, 2021
    K1577555224305 and rhyd1am like this.
  20. K1639770405776
    Cupcake Dec 17, 2021
    K1639770405776 , Dec 17, 2021 :
    My phone was better on day one than it is now with this dog s**t update. Stop breaking s**t that works.
    coffeekittie likes this.
