152
OxygenOS 11.1.1.2 for the OnePlus Nord
  1. dcschuitemaker
    Cupcake Mar 26, 2021
    dcschuitemaker , Mar 26, 2021 :
    I experience charing problems since installing this update. The phone only recognize that it's getting charged with the official charger and cable. When using a 3rd party charger + cable the phone doesn't recognized it's getting charged. The battery % is getting up but not recognized it's charging. This happen since the upgrade to Android 11. I have the latest version installed 11.1.1.2. I use the EU version of the Nord. Any advice? I already used multiple 3rd party chargers + cables to test.
    I found out it works with charging when I shutdown the phone and start it again.
    When I use the restart option and connect the cable the phone doesn't recognize it's getting charged.
  2. E1596528109109
  3. AnonymousWP
    The Lab - OnePlus 7 Pro Reviewer Mar 26, 2021
    AnonymousWP , Mar 26, 2021 :
    Maybe reading the openingspost will help. How hard is it? Literally nobody here ever reads. 11.1.1.1 was probably pulled and 11.1.1.2 is a hotfix of it.
  4. shweta..saini
  5. Dlappas
    Honeycomb Mar 26, 2021
  6. H1616704213687
  7. Ajithkumarc
    Cupcake Mar 27, 2021
  8. xcs
    Honeycomb Mar 27, 2021
    xcs , via OnePlus Nord Gray Onyx , Mar 27, 2021 :
    11.1.1.2 for sure is taking its time with the staged rollout ...
    I know no one from the OnePlus team is reading these forums but they sure have to improve the deployment system of the updates.
  9. chicku97
    Froyo Mar 27, 2021
    shweta..saini likes this.
  10. V1597224546699
    Froyo Mar 27, 2021
  11. greyscaleaddict , via OnePlus Nord , Mar 27, 2021 :
    Display scaling and font size are not the same as before.
    This needs to be fixed. Now the options for font size are less and it could either be large or very small with no options in between.
    Small display scaling option has been removed. Kindly re-add that option as well. Why would I buy a phone with a large screen if I can't see more content on it because now there's no small display scaling option.
    I don't know why OnePlus devs are lacking common sense while addressing these issues.
    khanaadil130 likes this.
  12. T1603724050413
    Donut Mar 27, 2021
    The.Millionaire likes this.
  13. X1596450547229
    Eclair Mar 27, 2021
  14. V1604690077942
  15. 9Abhishek
  16. MohanKumarAryan
    Gingerbread Mar 27, 2021
  17. khushal14_kk
  18. varman19
    Eclair Mar 27, 2021
    varman19 , via OnePlus Nord , Mar 27, 2021 :
    Wow, I just opened the community app to reply to the previous update thread about the power consumption issue, only to find an update to fix it..
    Hands down, you guys are one of the best. Kudos to all the efforts.
  19. Yashly , via OnePlus Nord Blue Marble , Mar 27, 2021 :
    Let me note down
    It feels sluggish while using.
    When double tap to on the screen it takes too much time to open or showing biometric.
    The toggle bar is lagging while using other apps like whatsapp and others. And it works smooth in home screen.
    While using biometric it shows yellow colour while opening the lock. This issues were not present in oxygen os 10. And changing brightness also becomes slow. (Extremely slow) and white biometric sign is totally a bad idea because when the brightness is low in sunlight it becomes too hard to find where is lock to put finger. Before the green biometric sign is too easy to find in extreme sunlight also.
    Take it seriously. Or otherwise just check my gmail id.
    thevinayjain and deepak2367 like this.
