152
OxygenOS 11.1.1.2 for the OnePlus Nord
  1. Yash_Tulsani
    Donut Apr 14, 2021
    Yash_Tulsani , via OnePlus Nord , Apr 14, 2021 :
    I am experiencing a new bug in which I can't operate both the apps in a split screen for example when I split screen chrome and whatsapp either the whatsapp is gonna work or chrome the other app won't show any signs of touch or anything
    I would like OnePlus Nord team toh work really hard upon fixing the bugs in updates or I might soon shift on any other company soon because from day 1 I am experiencing many bugs and issues on my nord
  2. hardyguns
    Froyo Apr 14, 2021
    hardyguns , via OnePlus Nord , Apr 14, 2021 :
    From recovery i reset the system settings
    Now my nord is working smooth and crazy fast and little less heating
    Minor issues still there
    -battery charging time still very much
    -Notification delayed
    Otherwise now its fine, try this may get your nord better
  3. iamsivareddy
    Gingerbread Apr 14, 2021
    iamsivareddy , via OnePlus Nord , Apr 14, 2021 :
    If it's issue with a Few you can ask for users to do beta testing and send a Detailed bug report , it's for 90% of the people. QA Test Engineers Sleeping ?
  4. iamsivareddy
    Wiped cache partition bro?
  5. thevinayjain
  6. hardyguns
    Froyo Apr 14, 2021
    Yes and reset system settings, basically my system was reset but my data saved on device was intact , except apps were all gone, basically reset but with data on your storage
    iamsivareddy likes this.
  7. Arijit Tah
    Cupcake Apr 15, 2021
    Arijit Tah , via OnePlus Nord , Apr 15, 2021 :
    Hey guys... Hopefully you all are doing well. Just want to let you know that after updating to OS 11.1.1.2 I am facing problems with the fingerprint scanner. Hope you guys will fix this bug soon
    Thanks
    Arijit
  8. R1610453069947
    moet.vijay likes this.
  9. ASHISHKISHAN
    Donut Apr 15, 2021
    ASHISHKISHAN , via OnePlus Nord , Apr 15, 2021 :
    Bro try to play in front of fan or AC . And don't let the phone temp to cross 38 degree c . It will work smoother. This is the temporary fix for pubg .
  10. 7386828637
  11. Master1999
    Eclair Apr 15, 2021
    Master1999 , via OnePlus Nord , Apr 15, 2021 :
    I don't think there is any fix yet.. It is taking much longer for a full charge now, hopefully they fix it soon
  12. X1603619755956
  13. saravanakumarkn
    Gingerbread Apr 15, 2021
  14. ManojN66
  15. A1597837925303
  16. iamharshoo
    Eclair Apr 15, 2021
    Anandeswaran likes this.
  17. vishal23927 likes this.
  18. rvsiyer
    Froyo Apr 15, 2021
    rvsiyer , via OnePlus Nord , Apr 15, 2021 :
    Try to downgrade and install Netflix and update I'm also facing same on zee5 app
  19. Fast_and_Curious
    Jelly Bean Apr 15, 2021
    Fast_and_Curious , via OnePlus Nord , Apr 15, 2021 :
    Just out of curiosity, what steps for troubleshooting have you taken to resolve the bugs?
    Charan3127 and Auristic like this.
  20. ManojN66
    ManojN66 , via OnePlus Nord , Apr 15, 2021 :
    Will Amazon Fire stick work, if I sync it to Nord?
