163
OxygenOS 11.1.4.4 for the OnePlus Nord
  1. norizam2503
    Froyo Aug 12, 2021
    norizam2503 , via OnePlus Nord , Aug 12, 2021 :
    me too, after updated os11 preferred 5g gone..wtf
  2. balani123
    Gingerbread Aug 12, 2021
    balani123 , Aug 12, 2021 :
    Screenshot_20210812-103037.jpg Screenshot_20210812-103048.jpg Screenshot_20210812-103105.jpg
    It is better but still drains at certain situations well I hope it's tuned for next update
    20-30% brightness
    No data only wifi
    WithGif wallpaper
    Vishnu.Zmr likes this.
  3. FF52
    Eclair Aug 12, 2021
  4. D1603444071790
    Cupcake Aug 12, 2021
    D1603444071790 , via OnePlus Nord , Aug 12, 2021 :
    Dear One plus team
    Please fix the issue of contact and Massage bugs.
    As shown notification of calling when will end up wth the call and also showing miss call notification continuous.
  5. R1596731912356
  6. Ankit khaire
  7. Ygdr4sil
    Honeycomb Aug 12, 2021
    Ygdr4sil , via OnePlus Nord Gray Onyx , Aug 12, 2021 :
    5% in 3 hours is completely normal, android system is using power even if you don't use the phone.
    Mobile network is using power all the time when it's on.
    Your image is only showing app usage, press the 3 dots and then press show device usage.
  8. jdkzzz
    Froyo Aug 12, 2021
    jdkzzz , via OnePlus Nord , Aug 12, 2021 :
    USE ONLY WI-FI - POSSIBLE SOLUTION TO INCREASING BATTERY LIFE
    Initially my Nord was getting 7-8hrs of SOT. Then after Android 11 update, it reduced to 4-5hrs. This latest update addresses battery drain issue but it didn't work for me.
    Suddenly on this Tuesday I got close to 8hrs of SOT and decent standby time after I changed my wallpaper to a static image and only used the internet via WiFi. Today, I switched to just using mobile data and I only got 4hrs of SOT and standby time seems to have gotten worse. See screenshots below for reference.
    So my guess is that using the phone on mobile data gives worse battery life which is not ideal for most Indian users LoL.
  9. jdkzzz
    Froyo Aug 12, 2021
  10. C1628753456485 , via OnePlus Community App , Aug 12, 2021 :
    Hello I am new to the android platform and it seems like I have found a neat little group that looked like a decent smart phone. I'm not real techy and I am completely illiterate when it comes to all this. But it interests me. That being said I have a platform specific version that is acting real glitchy I tried to download the oxygen updater from the play store but it won't let me use it. How can I fix this and what can I do to make it better
  11. balani123
    Yes it does work perfectly I would be butt hurt if it didn't ... Might I ask why isn't it working for you ?
  12. FF52
    Eclair Aug 12, 2021
    FF52 , via OnePlus Nord , Aug 12, 2021 :
    Dont know y.. plz dm me
  13. balani123
    Ya I done quite a few settings .. and disable many things that I not need
    This method will disable some features but here are few things that helped my battery
    Settings>apps>see all
    Then select show system on the top right and disable these
    Carrier services,Facebook's,quadcom voice,google assistant, assistant,cloud service, print service, Netflix,op account,etc
    I don't use those so it helps abit...
    Also settings>system>experience improvement.
    And double tap to wake, pocket sensor,wifi scan, bluetooth scan, message chat features,etc and vibration is the most battery consumption so on touch feedback is disabled with also touch sounds
    Intelligent wifi scan if using single wifi router at home . also open recovery and clear cache
  14. R1596731912356
    R1596731912356 , via OnePlus Nord , Aug 12, 2021 :
    Did the said settings but not much of help. No improvement . Of 15 min use battery down by 4% was just disabling apps which I'm not using
  15. balani123
    It should help a bit ... Umm 🤔 you might need to check your battery condition because if your phone heats up too much it damage the battery so use an app that can not just tell your battery condition but overall status
    Do post all 3 of your battery status e.g the one I did
  16. R1596731912356
  17. Neelanj
    E1624379767337 likes this.
  18. SlackW_1993
    KitKat Aug 12, 2021
    SlackW_1993 , Aug 12, 2021 :
    You are not talking to OnePlus support here only to simple users of the Forum.
    You are in the wrong thread (OS 11.1.4.4 dedicated to Nord 1st generation). Please use the thread dedicated to Nord 2.
    For suggestions or bugs it's here :
    To talk to OnePlus support it's here :
    OnePlus global support (call, email, chat) :
    https://www.oneplus.com/global/support/contact
    All countries selectable.
    Auristic and Neelanj like this.
  19. Naveen181
    Naveen181 , via OnePlus Nord 2 , Aug 12, 2021 :
    In Nord 2 while watching video in Netflix & prime video HDR doesn't supporting very disappointed with one plus team......you guys playing hide & seek game with the indian customers specially nord 2 phone...
    S1599112582517 likes this.
  20. SlackW_1993
    KitKat Aug 12, 2021
    Wrong thread. Please use the thread dedicated to Nord 2 instead.
    And no OnePlus Support here. Use the feedback section or OnePlus global support.
    Auristic likes this.
