100
OxygenOS 11.1.5.5 for the OnePlus Nord
  1. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member Sep 11, 2021
    Ghazala.Yasmeen , Sep 11, 2021 :
    In order to investigate this further we've sent a direct message please check for the same.
    Indrajit06 likes this.
  2. Ghazala.Yasmeen
    We are sorry to hear that you are facing the issue with the device and have contacted you through direct message.
  3. Ghazala.Yasmeen
    We may have to check this further and have contacted you through personal conversation.
  4. Ghazala.Yasmeen
    For analyzing this better we would need few details and have responded to you via direct message. 
  5. Ghazala.Yasmeen
    We understand your concern and relate to the issue you are facing and have contacted you via personal message.
  6. Ghazala.Yasmeen
    We have got in touch with you through personal message, request you to check for the same.
  7. Y1631122639221 , via OnePlus Nord N200 T-Mobile , Sep 11, 2021 :
    Hi. Just got my one+ Nord n200 and It seems that my nfc and Bluetooth are not working I do no what to do. When I'm trying to pair a new device it doesn't give me a names of the devices it just give me the device code that I can't identify who is it and what device it is plus it doesn't seem to connect to anyone. Plus my nfc doesn't work because I have diabetic blood glucose device that should be scanned with the phone using nfc and it doesn't want to read it at all I tryed doing a wireless charging and it also doesn't work. How can I fix those problems or I have to go to the store and change the device all together ? Thank you
  8. Y1631122639221 , via OnePlus Nord N200 T-Mobile , Sep 11, 2021 :
  9. Aronstark
    Gingerbread Sep 11, 2021
    Aronstark , via OnePlus Nord , Sep 11, 2021 :
    Bro follow this link..
    https://forums.oneplus.com/threads/oxygenos-11-0-1-0-na-for-the-oneplus-nord-n200.1460001/
    This is for your device..
  10. HoLeetihs
    Jelly Bean Sep 11, 2021
    HoLeetihs , via OnePlus Nord , Sep 11, 2021 :
    @Aronstark already mentioned you are in wrong thread since this one is for the 1st gen Nord. So this is getting to be off the topic but wireless charging wouldn't work because Nord N200 doesn't support it
    Auristic likes this.
  11. HoLeetihs
    This is a little off the topic but take a look to following screenshot :
    One is complaining that fps meter is not available anymore. Then OnePlus staff answered that they are sorry and would like to make further investigation and so on... said:
    Couple of things came to my mind. OnePlus removed the feature by the latest update so why they are giving answer like this? Do they really have solution how to get it work or do they tell why it was removed? Why they don't publish the reason for everyone?
    I don't need that meter in any way but that post looks strange to me
  12. Topper_Gas
    KitKat Sep 11, 2021
    Topper_Gas , Sep 11, 2021 :
    Probably because they haven't got a clue and that is their standard reply, there's loads of "we need to investigate this issue.." posts on here from OP, but little signs they actually fix the issues.
  13. V1631390798225 , via OnePlus Nord N10 5G , Sep 11, 2021 :
    Is this available in the US? My phone (N10) is on 11.0.1.BE86AA. When I go to System Update and check, my phone notes that the system is updated. Currently having issues with accessing my phone network (Verizon) since the upgrade to version 11. Any assistance would be appreciated.
  14. ngcsourav123
    Cupcake Sep 12, 2021
    ngcsourav123 , Sep 12, 2021 :
    Hi Everyone,
    I am currently using Android 10, build 10.5.7 on my Nord. Should I update to android 11? Is it worth it?
    Or should I stick to my current build. Please give your advice
  15. U1616774472864
  16. prakas99 , via OnePlus Nord Blue Marble , Sep 12, 2021 :
    I think you should stick on it for now
  17. Mathan G
    Froyo Sep 12, 2021
  18. SlackW_1993
    KitKat Sep 12, 2021
    SlackW_1993 , Sep 12, 2021 :
    If you keep up to date you're a bit late. You should have upgraded to Nord OS 10.5.11 first since February 2021 !
    Of course you can upgrade to OS 11.1.5.5. And you can also downgrade to OS 10 if you aren't satisfied.
  19. ashish960
    Honeycomb Sep 12, 2021
