55
OxygenOS 11.2.10.10 for the OnePlus 9 and OnePlus 9 Pro
  1. Rebel Rouser
    Froyo Nov 30, 2021
    Rebel Rouser , Nov 30, 2021 :
    I'm glad I haven't received it yet, by the time I do it means hopefully it will be 100% with all the bugs removed from earlier releases. 😎 😆
  2. B1617179021154
    Donut Nov 30, 2021
  3. Snivellus
    Cupcake Nov 30, 2021
  4. Ulysses92
    Eclair Nov 30, 2021
  5. Caomhin
    9 Series Expert, Participator of the Year Community Expert Nov 30, 2021
    Aaron2017 likes this.
  6. Destiny PA
    Eclair Nov 30, 2021
    Destiny PA , via OnePlus 9 Pro , Nov 30, 2021 :
    Use ******* oxygen updater if you can't wait.
    Alex.242 and Echoj8 like this.
  7. varun2211
    Cupcake Dec 1, 2021
  8. Sonisaleem
    Cupcake Dec 1, 2021
    Sonisaleem , via OnePlus 9 Pro , Dec 1, 2021 :
    I have the latest stable version installed (11.2.10.10) I have downloaded OB1 to install it and when it clicks to install it tells me: The version of the package you have selected is lower than the current version of the system. To avoid startup errors, installation of older versions is not allowed) So I can't install the beta version,help how to install android 12 ob 1
  9. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 1, 2021
    Caomhin , via OnePlus 9 Pro , Dec 1, 2021 :
    Backup your data and downgrade to an older build 11.2.9.9, then you can install OB 1 and then OB2 because 11.2.10.10 is a newer build date than OB1.
  10. Sonisaleem
    Cupcake Dec 1, 2021
    Tq
  11. Kl1mb
    Cupcake Dec 1, 2021
    Kl1mb , via OnePlus 9 Pro , Dec 1, 2021 :
    "Optimized the third-party app experience" - does that translate to "we fixed Gmail notifications"? Because after installing the update last night, Gmail pushes started working for me!!
    Abbas.B and MirceaForce like this.
  12. NANIIIII
    Donut Dec 1, 2021
  13. MirceaForce
    Honeycomb Dec 1, 2021
    MirceaForce , via OnePlus 9 , Dec 1, 2021 :
    Yes, and on Oneplus 8T the updates are detailed ...
  14. MirceaForce
    Yes you are 💯 right...
    There are people here that say that there are no issues on Oneplus 9 series...can you believe that?
    Or maybe they are using there phone only..as non smartphone....
    Vikas Sharma 7T and AarishRaza like this.
  15. MirceaForce
    Maybe after Beta 4...and the beta testers will receive first the update..
  16. MirceaForce
  17. Anshu2705
    Gingerbread Dec 1, 2021
    Anshu2705 , via OnePlus 9 Pro , Dec 1, 2021 :
    Don't understand why my battery is draining too quickly I haven't open it yet and within 13 min 4 % of battery drain without screen ON
    I know battery details are not available but it shows screen as 1% everytime is it with me only or anyone else is facing this issue
  18. Caomhin
  19. subsidiary likes this.
