55
OxygenOS 11.2.10.10 for the OnePlus 9 and OnePlus 9 Pro
  1. Anshu2705
    Gingerbread Dec 6, 2021
    MspyM likes this.
  2. tomtom07
    Cupcake Dec 6, 2021
    Caomhin likes this.
  3. Caomhin
    9 Series Expert, Participator of the Year Community Expert Dec 6, 2021
    Caomhin , via OnePlus 9 Pro , Dec 6, 2021 :
    And just for reference I have QHD+ 120hz and just about all features active though it has had some adjustments to save power with regards to WiFi and such. I don't use AOD, that can drain battery, have no need for it either. But I do use Ambient Display.
    Aaron2017 and tomtom07 like this.
  4. Aaron2017
    General Support Expert Award 2021 Dec 6, 2021
    Aaron2017 , Dec 6, 2021 :
    No, it's the same build number as the beta testers got a few days ago, it's Oxygen OS12
  5. tomtom07
    Cupcake Dec 6, 2021
    tomtom07 , via OnePlus 9 Pro , Dec 6, 2021 :
    Same here, i use ambient display, QHD+ 120hz, about the wifi settings could you please elaborate?
  6. Anshu2705
    Anshu2705 , via OnePlus 9 Pro , Dec 6, 2021 :
    So u r saying it's stable version of OS12 in 9 series?
    When did u received it and which country
  7. Naeem0809
    Froyo Dec 6, 2021
  8. Anshu2705
  9. MspyM
    Eclair Dec 6, 2021
  10. Caomhin
    I have these 2 disabled for WiFi.
    Disable "Sleep Standby Optimisation " in the
    Settings, Battery, Battery Optimisation, 3 dots menu top right, Sleep standby optimisation.
    Re-start your device.
    Also. Go to Settings, WiFi & Internet, WiFi, WiFi Preferences and disable Intelligently Select the best WiFi.
    Not sure if they save much but I set them this way and haven't had any battery issues. Not that I had any before. But I have them disabled anyway. And auto brightness enabled as well
    tomtom07 likes this.
  11. Aaron2017
    I didn't get it yet, from the looks of the thread i linked earlier it's India only as of now but of course also released in stages as usual. But it is stable yes, those that reported they have received it were all on the latest stable version of Oxygen OS
    Caomhin likes this.
  12. Anshu2705
  13. tomtom07
    Cupcake Dec 6, 2021
    Thanks a TON mate, done. As u said, I'll let it settle for week and see how it changes also turning ON "Optimise App Power Consumption" helps?
    Caomhin likes this.
  14. Aaron2017
    The build numbers are the same for both stable and beta. Which would indicate that beta testers are also on the same stable version now. The latest update they got, which everyone assumed was beta 3, appears to be a incremental update to get them to the stable version as they just now released and that beta program will probably be over.
    Caomhin likes this.
  15. maximus2708
    maximus2708 , Dec 6, 2021 :
    No data loss !!!
    VishnuYTC likes this.
  16. VishnuYTC
    Donut Dec 6, 2021
  17. Anshu2705
    Not possible it's would be OP beta update for sure
    If it's a OS12 then let's wait for week
  18. Naeem0809
    Froyo Dec 6, 2021
  19. Aaron2017
    Well, it is possible because that's what happened. It is indeed the stable version, unless the users in this thread are lying
    https://forums.oneplus.com/threads/android-12.1524465/
    You can check the last pages of the beta thread too, stable users reporting they have gotten the stable version too
    https://forums.oneplus.com/threads/...e-oneplus-9-and-oneplus-9-pro.1517825/page-79
