55
OxygenOS 11.2.10.10 for the OnePlus 9 and OnePlus 9 Pro
  1. [email protected]
    Gingerbread Nov 26, 2021
  2. Caomhin
    9 Series Expert, Participator of the Year Community Expert Nov 26, 2021
    Caomhin , via OnePlus 9 Pro , Nov 26, 2021 :
    5 post up ⬆️ from yours and also in the Main post top 🔝 of this thread.
    Helder_DAlmeida and Aaron2017 like this.
  3. SIDD7411
    Honeycomb Nov 26, 2021
  4. Sunay85
    Sunay85 , via OnePlus 9 Pro , Nov 26, 2021 :
    Does anyone feel overheating while charging, as if charging for 10 minutes after the update, it gets too hot compared to the previous update
  5. Javed.siddiqui
    Cupcake Nov 26, 2021
    Javed.siddiqui , via OnePlus 9 , Nov 26, 2021 :
    I have got one plus 9, 3-4 days back and every morning, it behaves frozen unless I restart the phone.
    Before restarting, I only can do one action and freeze.
    If I want to do second action I have to lock screen and unlock, then again only one action.
    Example, If I open an email from the alert, it freezes before the email loads, just shows the header of email. Then I have to lock and unlock the screen and mail loads.this happens with all apps.
    Any help!??
  6. joe carrow
    joe carrow , Nov 26, 2021 :
    Good Share! Appreciated!
  7. OConsultYaseenP
    RevidFfum and ady_agar like this.
  8. D1621226592647
    D1621226592647 , via OnePlus 9 , Nov 26, 2021 :
    Use oxygen updater from playstore if you don't want to wait. I've not received the update either. In the UK.
  9. Caomhin
    Seen it take up to 21 days, more often 14, but who knows. OP control the servers and release timeframe. 👍
    Aaron2017 likes this.
  10. Caomhin
  11. Caomhin
    9 Series Expert, Participator of the Year Community Expert Nov 27, 2021
    Caomhin , via OnePlus 9 Pro , Nov 27, 2021 :
    This is not a normal Android issue it sounds like a 3rd party security app you may have installed is causing the issue. If you have an anti virus app installed. Disable it temporarily to see if the error still shows up. The following link applies to a Windows PC, however the basics still apply to any OS. Check if anything mentioned can help in any way.
    https://appuals.com/fix-debugger-has-been-found-running-in-your-system/
  12. ChirantanMandal6 , via OnePlus 9 Pro , Nov 27, 2021 :
    I use oxygen OS Updater app. For update my oneplus 9 Pro
  13. Caomhin
    So do I, I haven't seen that specific error before.
    If you don't see any improvement after trying the suggestions given. Please send Bug reports and give Feedback on the issues back to the OnePlus OOS developers. So that they can investigate them.
    And you can also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for Email, Phone contact and online Chat details.
    Aaron2017 and D1621226592647 like this.
  14. Ajay33
    Gingerbread Nov 27, 2021
  15. vagee17
    Froyo Nov 27, 2021
    vagee17 , via OnePlus 9 Pro , Nov 27, 2021 :
    It's high time you start mentioning what bugs were fixed or what stability has been improved!
    Every time there's a update you say this, but unfortunately doesn't help. Still there are a lot of bugs on these so called "Flagship Killler"
    Some of the bugs mentioned here:
    1. Wallpaper changes automatically to default one or completely turns black very often
    2. Gmail notifications for new mails doesn't comes up until you open the app
    3. Some apps gets stuck or phone completely hangs to death while playing games when phone goes in battery saver mode
    4. etc etc etc. I'm so used to these bugs that I forgot most of them. No hopes of OnePlus settling on these bugs!
    Cristian75 and RevidFfum like this.
  16. MunshiDanish, Vishnu.Zmr and Ajay33 like this.
  17. Seppo
    Eclair Nov 27, 2021
    Seppo , via OnePlus 9 , Nov 27, 2021 :
    No, Same Battery Life than before. I get 6-8 Hours SOT.
    Akshay Haridas likes this.
