70
OxygenOS 11.2.4.4 for the OnePlus 9 and OnePlus 9 Pro
  1. JelleZon likes this.
  2. Jamz2710thomas
    Cupcake Apr 26, 2021
    peterbok likes this.
  3. Vaishnav Sheelam91
    Vaishnav Sheelam91 , via OnePlus 3 , Apr 26, 2021 :
    The S21+ is a proper contender to OP 9Pro. SD 888 (US version), holds excellent camera in the current market, hell lotta internal features provided by samsung, 15w wireless charging, 25w wired charging, 4800mah battery. More or less the core features remain similar to OP 9Pro.
    Glass back panel , stereo speakers, matte finish phantom black , 120hz adaptive display, ultra sonic finger print scanner,Unlimited 4k recording, Has telephoto lense, and the list goes on. Supports a lot of 5g bands. Samsung provides major updates for 3 years.
    Differences rather setbacks:
    1. 25 watts charging
    2. Not a stock android. Will have to get used to the One UI, and it's not that bad.
    3. Supports only 15watts of wireless charging
    4. Does not have a slider like OnePlus on the side.
    5. Expensive than OnePlus
  4. Jamz2710thomas
    Jamz2710thomas , via OnePlus 9 , Apr 26, 2021 :
    I have got no idea. The battery is running out more faster than usual. I brought the phone charge upto 96 % in the afternoon and didn't use the phone much after that but still had to charge in the evening as the battery was down to 15%
  5. Ultradyong
    Gingerbread Apr 26, 2021
    Ultradyong , via OnePlus 9 Pro , Apr 26, 2021 :
    The color for camera has been sharpen, but auto-rotate to landscape mode need a few work around and I noticed that Netflix fail to play clearly in dark setting like in the dark trying to see it is difficult due to night setting in the device overly expose to the dark color sharpening.
  6. Tsoares86
  7. Venkat03
    Cupcake Apr 27, 2021
  8. Djoon
    Eclair Apr 27, 2021
    Djoon , Apr 27, 2021 :
    I don't understand people, make all the frequencies lower quality or disable a lot of functions, use an average smartphone function, then you have nothing to buy expensive smartphones, buy an average budget Smartphone and enjoy, Expensive Smartphones should work to full capacity and to the functionality itself, do not need to disable anything lower
  9. Vaishnav Sheelam91
  10. O1618995030564
  11. X1619418716752
    S1618750344347 likes this.
  12. KDeepanshu
    KDeepanshu , via OnePlus 9 , Apr 27, 2021 :
    After the update.i am facing the heating issue more and more. Even after restarting it. And my battery life has also decreased. And the gallery takes alot of time to show my latest photos. Kindly solve this issue as soon as possible.
    Kazim_Selma and G_Chee_Seng_vsTK like this.
  13. ajaysakpal
    Eclair Apr 27, 2021
  14. LokenderPilaniya , via OnePlus 9 Pro Pine Green , Apr 27, 2021 :
    I believe buying and using a device depends on user to user and there is no universal rule on how you use your device or the things you buy. Like if someone got a Ferrari, it doesn't mean he has to use it's full power all the time.
    The point is people buy things which works for them and are capable of power delivery on demand.
  15. goku6666
    Gingerbread Apr 27, 2021
  16. krishna.MR
  17. krishna.MR
    Deactivated User likes this.
