44
OxygenOS 11.2.4.4 for the OnePlus 9R
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Jul 29, 2021
    Caomhin , via OnePlus 9 Pro , Jul 29, 2021 :
    All Oneplus Contacts, Messages and Phone apps are no longer supported since the Google Comms came with the Nord and all newer phones. It's going to a happen at some stage, where they will code OOS and none will work only the default Comms apps the phone came with or those that can be downloaded from the Playstore.
    https://forums.oneplus.com/threads/...and-messaging-apps-discussion-thread.1432733/
    #81
    SLHaokip likes this.
  2. SLHaokip
    Cupcake Jul 29, 2021
    #82
  3. SLHaokip
    #83
    Caomhin likes this.
  4. Caomhin
    Check my reply to you above, its no longer supported.
    #84
  5. Huigiebaby
    Ice Cream Sandwich Jul 29, 2021
    #85
    Caomhin likes this.
  6. Kesavan_Kesavv
    Eclair Jul 29, 2021
    #86
  7. A1618487185646
    Eclair Jul 29, 2021
    #87
  8. Anandasr
    Donut Jul 30, 2021
    Anandasr , via OnePlus 9R , Jul 30, 2021 :
    Yes u also feel that .. and i think it can do much better if the add haptic feedback to certain apps like instagram where we see a preview of an image while holding it .. iphone gives a feedback in this things hope they add it to more things
    #88
  9. ketu3846
    Cupcake Jul 30, 2021
    #89
  10. Khasim_ABCD
    Gingerbread Jul 30, 2021
    Khasim_ABCD , via OnePlus 9R , Jul 30, 2021 :
    Version 6.0.0.1.201015035850.868b175
    Is this same version you're using on your mobile for OnePlus sms app.
    #90
  11. Ankit98gupta01
    Donut Jul 30, 2021
    #91
    ParimalPan likes this.
  12. O1625508534004
    Froyo Jul 30, 2021
    O1625508534004 , via OnePlus 9R , Jul 30, 2021 :
    This oxygen os have have a issue
    Battry drain fast
    And low britness display was blinking issue is not fixed
    Ye display blinking issue kab fix hogaa.........
    #92
  13. SLHaokip
    SLHaokip , via OnePlus 9R , Jul 30, 2021 :
    I don't know. Since Google message app introduced the category-wise grouping similar to OnePlus messaging, i decided to try out the Google one and deleted my OnePlus messaging. I don't have it anymore but wanted to have it again so i searched in Playstore and couldn't find it anymore. Googled it and it simply said my device is no longer compatible.
    #93
  14. sagar@k
    Froyo Jul 30, 2021
    #94
  15. SLHaokip
    #95
    Caomhin likes this.
  16. K1626019685150
    K1626019685150 , via OnePlus 9R , Jul 30, 2021 :
    After update my refresh rate is showing 60 in ufo fps meter and it seems the device is laggy.before update it shows 120 fps in ufo test.after i restart the phn becomes smooth like before but still showing 60fps.any tips to skip the lagness in the ui and launcher.
    #96
  17. Ahuja.akshat
    Eclair Jul 30, 2021
    Ahuja.akshat , via OnePlus 7 , Jul 30, 2021 :
    Bought the 9R. My unit has display tint issues. If I tilt my phone slightly, the display tint changes to pink. Anyone else facing this? Any help would be appreciated. Thanks.
    #97
  18. shubhbeing
    Donut Jul 30, 2021
    #98
  19. kapil1984
    Froyo Jul 30, 2021
    #99
  20. B1619100523901
    B1619100523901 , via OnePlus 9R , Jul 30, 2021 :
    There's a little difference in camera cutout 9r camera cutout is little bit big then 8t
