87
OxygenOS 11.2.6.6 for the OnePlus 9 and OnePlus 9 Pro
  1. archon810
    Eclair Jun 6, 2021
    snke likes this.
  2. kriscool77
    Eclair Jun 7, 2021
    kriscool77 , via OnePlus 9 Pro , Jun 7, 2021 :
    Yes the issue still exists. 😪
  3. kriscool77
    Eclair Jun 7, 2021
    Never ever gonna sail the OnePlus Boat again. This after the 11.2.7.7 update. I sketch a lot and I like having Music in the Background so I set this device down with Music playing from Amazon Music. Just after 45 mins it got so damn hot. Never had these type of issues with my previous devices and none of them were from OnePlus. Yes some people have heating issues some don't but a huge number of people still have this issue which only means one thing inconsistency in Manufacturing. For example the OnePlus 8 series a big number of people had display issues some didn't. Just look at the OnePlus Instagram page for Pete's sake it's glaring with Heating complains.
    Neil Vinod and killingclown007 like this.
  4. kriscool77 likes this.
  5. killingclown007 , via OnePlus 9 Pro , Jun 7, 2021 :
    Very trueee
  6. Niklasg85
    Honeycomb Jun 7, 2021
    Niklasg85 , via OnePlus 9 Pro , Jun 7, 2021 :
    If there was a problem with some units after manufacturing, why didn't some of you put an RMA and send them back?
    I do see that they have resolved some of the heat issues with 12.11.6.6 already. I didn't have the phone since start but i did notice some problems with heat.
    It also depends on your usage envoirment, in India it's maybe like +40 degress celisus, here in Sweden it's has been like +25 degress Celsius.
    So please stop complain and report in the feedback section if the phone gets to hot and give you a warning of the heat. You must also describe the scenario when it occured.
    Give them a chance to fix if they can by software to trim the overall power consumption and so on...
    woSch likes this.
  7. kriscool77
    Eclair Jun 7, 2021
    Bruh where I'm at right now it's 27°C and it still heats.
    Niklasg85 likes this.
  8. Niklasg85
    Please report the issue. And what's the temperature of the unit? You can easily see it if you dial *#800# then go in to section "tools" and then "charger" mine is constantly between 30-38 at max. If i do heavy stuff like gaming Call of duty, PUBG or similar it gets to about 39 at the max 40.
    If it goes past 45 then you should get a heat warning and services is getting "strangled". said:
    I suggest that you report the issues when it occurs and give them a user scenario when it occurs. Example with playing this game, shooting a video in this resolution, whats the temperature in the air, if it's while you charge or not and so on...
    here is a guide sir https://forums.oneplus.com/threads/...uct-suggestions-on-oneplus-community.1002970/
    woSch likes this.
  9. mclarenf1lm
    Eclair Jun 7, 2021
    mclarenf1lm , via OnePlus 9 Pro , Jun 7, 2021 :
    Pro Mode in camera is some kind of broken. The same settings of WB, shutter and ISO and in normal mode photos looks good, and in pro mode with the samw settings photos are dark.
    Normal mode, ISO 200, shutter 1/160, AWB
    Pro Mode, ISO 200, shutter 1/160, AWB said:
    FIX THAT PLEASE !
  10. W1542986990811
    Cupcake Jun 7, 2021
  11. kriscool77
    Eclair Jun 7, 2021
  12. Q1620816256653 , via OnePlus 9 Pro , Jun 7, 2021 :
    Gmail notifications were working fine for me about an hour ago.....And now all of a sudden I have stopped receiving notifications from the app...Anyone else experiencing this ??
  13. N1622290636693
    Cupcake Jun 8, 2021
  14. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member Jun 8, 2021
    Ghazala.Yasmeen , Jun 8, 2021 :
    We understand your concern and relate to the issue you are facing and have contacted you via personal message
  15. Ghazala.Yasmeen
    We may have to check this further and have contacted you through personal conversation.
  16. Ghazala.Yasmeen
    We have got in touch with you through personal message, request you to check for the same.
  17. Ghazala.Yasmeen
  18. adnan.makarevic
    Cupcake Jun 8, 2021
    adnan.makarevic , Jun 8, 2021 :
    Thank you sooooooo much guys for enabling 5G!!
    Love you all!
    Best
  19. Harish_Krishnaswamy , via OnePlus 9 Pro , Jun 8, 2021 :
    Same issue battery draining much heating on normal use
