79
OxygenOS 11.2.8.8 for the OnePlus 9 and OnePlus 9 Pro
  1. PuCiNhOOO
    The Lab - OnePlus 8 Pro Reviewer Jul 22, 2021
    PuCiNhOOO , via OnePlus 9 Pro , Jul 22, 2021 :
    A purple dot in the screen? Or are you being able to see it through the viewfinder?
    That is the lazer focus light
  2. PuCiNhOOO
    Dresa91 likes this.
  3. veda2810
    Honeycomb Jul 22, 2021
  4. Ninxha
    Gingerbread Jul 22, 2021
    Ninxha , Jul 22, 2021 :
    Are you on latest update 11.2.8.8? If not i would suggest either download full ota of 11.2.8.8(3gb zip file) and flash it through System Updates, or doing a Factory Reset to see if its solved. This second one will delete your data so make a backup before if you go for this.
    Dresa91 likes this.
  5. PuCiNhOOO
  6. Bruno Lugnani
    Ice Cream Sandwich Jul 22, 2021
    Bruno Lugnani , via OnePlus 9 Pro , Jul 22, 2021 :
    Yes around 5C lower now.
  7. kingracer
    Froyo Jul 22, 2021
  8. Bruno Lugnani
    I am now using it on the beach, it reaches around 40C but until now not any overheating alert
  9. kingracer
    Froyo Jul 22, 2021
    kingracer , via OnePlus 9 Pro , Jul 22, 2021 :
    Wow... Do you have Chinese model or some other one?
  10. Bruno Lugnani
  11. kingracer
    Froyo Jul 22, 2021
    Bruno Lugnani likes this.
  12. Ninxha
    same do i lol, and thats what i got xD from what i've observed, i feel like Chinese version has less SOT than other versions. Max SOT i've reached is 7 hours and that happened with a custom kernel.
  13. kingracer
    Froyo Jul 22, 2021
    7h of SOT is a huge amount of time comparing to my 3-4, so that's still great, even with custom kernel) but anyway I'm even not as disappointed with SOT, as with overheating and camera issues...
  14. NANIIIII
    Cupcake Jul 22, 2021
    NANIIIII , via OnePlus 9 Pro , Jul 22, 2021 :
    Few days back only I did the factory reset and yesterday I downloaded the new update also
    RazvanScutea likes this.
  15. RazvanScutea
  16. Ajay33 , via OnePlus 9 Winter Mist , Jul 22, 2021 :
    I noticed that battery has been improved a bit, gmail notification is working now and heat has been reduced a bit. Youtube auto resuming issue has been addressed.
    But it takes around 50mins to charge, Camera details are fine if i look into the view finder but after processing it becomes blurry and focusing issue still there. Camera hasn't been changed a bit in this update i guess. Scrolling apps like youtube is slow(im not feeling the speed of 120hz while using some apps) and there are some stutters here and there. Camera color inconsistency between main lens and wide angle and while taking videos ,it looks over sharpened in only some of the scenarios.
    Hoping that every issue will be fixed after releasing android 12 🤞
  17. Ninxha
    Usually i get 5-6 hours SOT. 5 when playing 1-2 hours games, 6 when not playing :p I dont mind this SOT tbh since fast charging is amazing....I dont have any problems with overheating for now and i dont know what problem you have with camera?
    Dresa91 likes this.
  18. Ninxha
    If you don't mind doing another factory reset i have a way i can show to you that might fix your problems. Write me on messages, if you do not mind factory resetting again.
    Dresa91 and NANIIIII like this.
  19. Huigiebaby
    Huigiebaby , Jul 22, 2021 :
    Ninxha, Neil Vinod and Dresa91 like this.
