75
OxygenOS 11.2.8.8 for the OnePlus 9 and OnePlus 9 Pro
  1. R1616395661132
    Cupcake Jul 22, 2021 at 12:35 PM
  2. Huigiebaby
    Ice Cream Sandwich Jul 22, 2021 at 12:40 PM
  3. NANIIIII
    Cupcake Jul 22, 2021 at 12:46 PM
  4. L1622550721409
    Eclair Jul 22, 2021 at 12:52 PM
  5. veda2810
    Honeycomb Jul 22, 2021 at 1:29 PM
  6. N1600417325693
    Cupcake Jul 22, 2021 at 1:43 PM
  7. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 22, 2021 at 1:47 PM
    Dresa91 , Jul 22, 2021 at 1:47 PM :
    Do you already have the stable code from Google?
  8. Destiny PA
    Donut Jul 22, 2021 at 1:56 PM
  9. Ninxha
    Gingerbread Jul 22, 2021 at 2:13 PM
    Ninxha , Jul 22, 2021 at 2:13 PM :
    I dont think its a software problem... but time will tell :/
    Dresa91 likes this.
  10. FlugzeugSK
    Honeycomb Jul 22, 2021 at 2:13 PM
  11. L1622550721409
    Eclair Jul 22, 2021 at 2:14 PM
  12. Ninxha
    Gingerbread Jul 22, 2021 at 2:16 PM
    Ninxha , Jul 22, 2021 at 2:16 PM :
    You can downgrade only to 11.2.5.5 and then update to 11.2.7.7. Downgrading will wipe data. Or if you use MSM tools you can just flash whatever update you want but that requires skills and a computer and u might mess up and brick your phone. So best is downgrade to 11.2.5.5 and update to 11.2.7.7(again not forget your data will be wiped)
    Dresa91 likes this.
  13. L1622550721409
    Eclair Jul 22, 2021 at 2:17 PM
    L1622550721409 , via OnePlus 9 Pro , Jul 22, 2021 at 2:17 PM :
    Ok how can I do that ? :-( downgrade to 11.2.5.5
  14. S1615553694836
    Donut Jul 22, 2021 at 2:17 PM
  15. Dresa91
    User of the Year 2016; Most Active User 2020 Jul 22, 2021 at 2:19 PM
    Dresa91 , Jul 22, 2021 at 2:19 PM :
    It is written in the post, read again:
    Ninxha likes this.
  16. FlugzeugSK
    Honeycomb Jul 22, 2021 at 2:19 PM
    FlugzeugSK , Jul 22, 2021 at 2:19 PM :
    just curious, what do you expect from downgrade, there are only "minor" changes between 11.2.7.7 and 11.2.8.8
    maybe there is no need to dongrade, wipe data etc..
  17. L1622550721409
    Eclair Jul 22, 2021 at 2:20 PM
    L1622550721409 , via OnePlus 9 Pro , Jul 22, 2021 at 2:20 PM :
    Read my previous comments, a super annoying bug is effecting my phone since the new update has been installed
  18. Ninxha
    Gingerbread Jul 22, 2021 at 2:22 PM
    Ninxha , Jul 22, 2021 at 2:22 PM :
    Go here: https://forum.xda-developers.com/t/oneplus-9-pro-rom-ota-oxygen-os-repo-of-oxygen-os-builds.4254587/
    You will find "Downgrade Zips" there. Open it, find below Your Country for example for India , open it and download the LE15DA: 11.2.5.5 Rom. After replace the ".jar" in the end with ".zip" in the end of the file that you downloaded. Move it from Downloads folder to Internal Storage folder. Then go System Updates- Local upgrade - select the file you downloaded and click continue install, reboot and you are good to go. Then manually update to incremental 11.2.7.7 using Oxygenos Updater.
    D1621226592647 and Dresa91 like this.
  19. Ninxha
    Gingerbread Jul 22, 2021 at 2:23 PM
    Ninxha , Jul 22, 2021 at 2:23 PM :
    Dresa91 likes this.
  20. FlugzeugSK
    Honeycomb Jul 22, 2021 at 2:25 PM
    FlugzeugSK , Jul 22, 2021 at 2:25 PM :
    what exactly do you mean by "dedicated button" ?
    The power button on side ?
