124
OxygenOS 11.2.9.9 for the OnePlus 9 and OnePlus 9 Pro
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 21, 2021
    Caomhin , via OnePlus 9 Pro , Sep 21, 2021 :
    Patience will be rewarded, I'm sure.
    Helder_DAlmeida and Aaron2017 like this.
  2. P1628105778360
    Cupcake Sep 21, 2021
    amitkumarnath143 and aziz25 like this.
  3. aziz25
    Froyo Sep 21, 2021
    aziz25 , via OnePlus 9 Pro , Sep 21, 2021 :
    Before 5 to 5h30 SOT and til now after update 5-5h30 SOT same screen on time nothing special
  4. Sash Shh
    Froyo Sep 22, 2021
    Helder_DAlmeida likes this.
  5. Teja1999
    Gingerbread Sep 22, 2021
    Oneplus suman likes this.
  6. Oneplus suman
  7. Andy lone
    Honeycomb Sep 22, 2021
  8. soham.parekh_
    Eclair Sep 22, 2021
    soham.parekh_ , via OnePlus 9 Pro , Sep 22, 2021 :
    I tried you say and also uninstall and install again but this night also happens again
    What is the problem? Is problem with Oxygen Os new update or Snapchat problem
  9. MythicalAnimal
  10. Helder_DAlmeida likes this.
  11. edwinmarkus
    Cupcake Sep 22, 2021
  12. upD8R
    Donut Sep 22, 2021
    upD8R , via OnePlus 9 Pro , Sep 22, 2021 :
    Anybody else having GPS issues with this release? Runkeeper finds the location but as soon as I turn off the screen or move the app to the background it doesn't receive any location update. I can run 10 minutes and haven't moved 🙄
    It's not limited to Runkeeper, same happens if I track a workout with Zombies, Run or start an activity on my Wear OS watch.
    Permissions and battery optimization were checked.
  13. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 22, 2021
    Caomhin , via OnePlus 9 Pro , Sep 22, 2021 :
    You may need to contact Snapchat support and see if they have a solution for you.
    Also give Feedback on the issues back to the OnePlus OOS developers. So that they can investigate them.
  14. Caomhin
    Remove any screen protector on place so that your finger is hitting the screen directly. If this works, then the screen protector is your problem.
    Once removed or If you don't have a screen protector and the issue is still there.
    Clear all Screen Locks completely, Pin, Fingerprint, Pattern and Facelocks etc
    Also do a search for biometrics (Lower case) as per the image below, and if its available, Clear the Biometrics Service App info Cache and App info Storage as well.
    Restart the phone and set up the Fingerprint once more.
    For additional info on Android Fingerprint issues, please check the website below.
    https://www.carlcare.com/global/tips-detail/fix-android-fingerpint-not-working
  15. V1626505518994
  16. G_Saleem_Shaikh_qUFl , via OnePlus 9R , Sep 22, 2021 :
    Hi.....
    I have Recently purchased OnePlus 9R handset, & my earlier handset was OnePlus 7Pro. OnePlus Handsets are really good for use and performance, what I have seen in 7pro, but unfortunately that handset got stolen so I purchased this new 1.
    Now the matter is I'm not abe to use the Union Bank of India app for Banking purpose in this handset, earlier handset has no issue. Now m not getting the point whether the handset has the issue with app or the banking app has the issue. I have spoken with the bank customer service n tried as per there instructions, but it doesn't work. So now I have joined this community to get any ideas or update from OnePlus to get solved this issue.
    Please check and release a update.
  17. Caomhin
    This seems to be a common issue on the 9R. Please do a search for Union Bank or Union Mobile here in the Community. Some managed to Fix their issues, but the same suggestions had a mixed reception for others. You may get a solution from the many suggestions given in other threads.
    If you do fix it, please do post what may have helped.
    Aaron2017 likes this.
  18. Nisse_Eriksson_Alfta
    Nisse_Eriksson_Alfta , Sep 22, 2021 :
    When is it possible that 11.2.9.9 reaches Sweden?
  19. Aaron2017
    Lollipop Sep 22, 2021
    Aaron2017 , Sep 22, 2021 :
    Depends on when the staged rollout reaches your device, you won't be able to get an exact ETA on that. Starting from release it could take a couple of weeks.
    Caomhin and Nisse_Eriksson_Alfta like this.
  20. Tompi-One
    Froyo Sep 22, 2021
    Tompi-One , via OnePlus 9 Pro , Sep 22, 2021 :
    € 150 patience?
    Funny...
    It is a bad OnePlus strategy to have an LHDC earpiece but you can't use your knowledge with your own premium phone ...
