124
OxygenOS 11.2.9.9 for the OnePlus 9 and OnePlus 9 Pro
  1. kamzee96
    Honeycomb Sep 22, 2021
    kamzee96 , via OnePlus 8T , Sep 22, 2021 :
    My 9 pro was overheating with just 1 min into video recording outside.
    YO3INQ likes this.
  2. Z1621926200724
    Eclair Sep 22, 2021
  3. ronnyhawks320
    Ice Cream Sandwich Sep 22, 2021
  4. SKSomesh
    Cupcake Sep 23, 2021
  5. C1624788922607
    Gingerbread Sep 23, 2021
  6. rkrajnish07
    L1622550721409 likes this.
  7. Aaqilfas
  8. Alxfly
    Jelly Bean Sep 23, 2021
    Alxfly , via OnePlus 9 , Sep 23, 2021 :
    Do you any problem with the bluetooth ?
    Since the update. I have some difficulty with the connection in my car. I need to reboot my phone and delete the association to made a new one.
  9. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 23, 2021
    Caomhin , via OnePlus 9 Pro , Sep 23, 2021 :
    It will differ from user to user, depending on how they customise and use their phone. 120hz, QHD+, AOD, Gaming, and many other factors, even climate can have an impact.
    Anything between 5 hours and I have seen a few go up to 11 hours from a full charge to zero.
    It would be impossible to give an average.
    Here are some recent reviews to check out and compare what they say.
    https://www.tomsguide.com/reviews/oneplus-9-pro
    https://uk.pcmag.com/mobile-phones/132398/oneplus-9-pro
    https://www.popsci.com/reviews/oneplus-9-pro-review/
    Aaron2017 and Aaqilfas like this.
  10. Caomhin
    Reset the Bluetooth adapter on the phone, Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also try the suggestions at the site below to see if it can help your Bluetooth issues.
    How to Fix Bluetooth Pairing Problems
    https://www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/comments-/CP8/
    Then pair them back up again. Check if this can help.
    ronnyhawks320 and Aaron2017 like this.
  11. Alxfly
    Thanks for this information, I will try it and tell the result
    Caomhin likes this.
  12. Vinay Raghvani
    Honeycomb Sep 23, 2021
  13. k26d1310s
    k26d1310s , via OnePlus 9 Pro , Sep 23, 2021 :
    after every possible solution (logkit recording and sharing to one plus team, 4 different dialers, 3 proximity sensor apks) screen persistently refuses to wake up after a call ends. its really shame, a problem that should not be a problem since 2010....
    YO3INQ likes this.
  14. KaustubhNaik95
  15. YO3INQ
    Eclair Sep 23, 2021
  16. YO3INQ
    Eclair Sep 23, 2021
    kamzee96 likes this.
  17. Brydges81
    Froyo Sep 23, 2021
    Brydges81 , via OnePlus 9 Pro , Sep 23, 2021 :
    What version is the launcher on in this new update? I'm also having RAM issues but mostly very buggy launcher on 5.1.10 with my 8/256 model. Launching Camera or intense 3D games will actually clear my launcher and my wallpaper will factory reset to the out-the-box one. The notifications have also a weird bug after disabling Work-Life Balance I get a constant blank space where it was in my notifications panel pushing all the notifications down. So my question is, how did you go about fixing th we issues? I'm just hoping OxygenOS on Andriod 12 will bring back the software stability I had with my previous 1+ devices before I got the 9 Pro.
  18. Yijiayijia
    tomtom07 likes this.
  19. Caomhin
    Not sure of current default Launcher on 11.2.9.9.
    I currently use this OnePlus Launcher versiin 5.2.28 for the last couple of weeks, it's an apk from the Nord 2 and is extremely smooth on my 9 Pro with 11.2.9.9.
    https://www.apkmirror.com/apk/onepl...oneplus-launcher-5-2-28-android-apk-download/
  20. gichan
    Froyo Sep 23, 2021
