140
OxygenOS 11.2.9.9 for the OnePlus 9 and OnePlus 9 Pro
  1. evgenybu
    Cupcake Oct 27, 2021
  2. MirceaForce
    Gingerbread Oct 27, 2021
    MirceaForce , Oct 27, 2021 :
    maybe it's not the worst phone ..but the support is very poor
  3. MirceaForce
    maybe we will have to wait until February for the oxygen os 12 final version ....
  4. oTeMpLo
    Nebste76 and X1567496646380 like this.
  5. MirceaForce
  6. X1567496646380
    X1567496646380 , Oct 27, 2021 :
    So right...
    Nebste76 and oTeMpLo like this.
  7. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 27, 2021
  8. MirceaForce
  9. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 28, 2021
  10. Caomhin
    Caomhin , via OnePlus 9 Pro , Oct 28, 2021 :
    Have to say Battery life on 11.2.9.9 on the 9 Pro is absolutely phenomenal. 120hz, QHD+, Ambient display, No AOD or No gaming though. Can't fault it.
  11. Caomhin
  12. kãräñ_90564
    Ice Cream Sandwich Oct 28, 2021
    kãräñ_90564 , Oct 28, 2021 :
    Question to OnePlus 9 series users using OOS11...
    Hey guys, anyone having slow storage speed issue in OOS11 like OnePlus 7 series users facing? It feels slow when opening app like Gallery, It lags while loading images takes time to settle down then goes to normal.
    Earlier in OOS 10 it was never happened like that, whenever I opened gallery, images were already loaded and had no loading at all.
    Nvidia70 likes this.
  13. Caomhin
    Nope, Gallery opens fine on my 9 Pro. Clear the OnePlus Gallery App info Cache and App info Storage as well. See if that helps.
    Also, as both the Camera and Gallery are linked.
    Clear the Camera App info Cache and App info Storage.
    Also Clear the OnePlus Camera Service App info Cache and App info Storage as well.
    Restart the phone. Check if this can help.
    kãräñ_90564 likes this.
  14. kãräñ_90564
    Thanks for replying dude. Even the hard reset from recovery could not fixed this issue. I was collecting information from OOS11 users from each series which I will use in reporting detailed feedback for that storage speed issue. I got so many trouble finding the answer because of deletion of my post by mods, for invalid reasons I don't know why. BTW Finally I got the answer. Thankyou so much.
    Caomhin likes this.
  15. mingtakchu
    Cupcake Oct 28, 2021
  16. N1633804888618
    N1633804888618 , via OnePlus 9 , Oct 28, 2021 :
    Double to wake during calls using bullet wireless z bass edition neck band doesnt works have to press the power button to wake up the screen..also the same headset also doesnt auto connects many times when Bluetooth is on..but works fine with other handsets.. Anyone else also facing these same in OP9??
  17. O1581865254223
    Cupcake Oct 29, 2021
  18. J1635139811008
    J1635139811008 , via OnePlus 9 , Oct 29, 2021 :
    Getting issue with WIFi connection. Its not stable at all, gets auto dropped continuously.
    My other mobile handsets do not have this issue. Using samsung and MI.
    This is my first one plus nad i am disappointed with wi fi connection stability..
    Please advise setting changes if any or update with a patch.
    Thanks
    soham.parekh_ likes this.
  19. Swejuggalo
    OnePlus 9 Series Expert Community Expert Oct 29, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Oct 29, 2021 :
    There are multiple possible reasons.
    Possible fixes. Change channel on the router. Disable random mac on the phone. Disable Smart Connect if used on router. Switch to WPA3 on router. Update firmware on router. Enable/disable WiFi 6 on router.
    Don't know what your other clients are... But do any of the others use the same SoC/modem? There can be certain combos of router/settings/SoC that don't play nice together.
    You can also report it via the feedback tool.
  20. Alex.242 and Ultradyong like this.
