408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. K1541939756962
    Eclair Aug 24, 2021
  2. Rohan Vishwakarma
    Cupcake Aug 24, 2021
  3. shawdharmesh
    Eclair Aug 24, 2021
    shawdharmesh , via OnePlus 6 , Aug 24, 2021 :
    I've installed beta 3 of OOS 11 but now want to install the stable version.. I've downloaded the file from XDA but unable to do a local upgrade.. what should I do?
  4. Vikashlb
    Honeycomb Aug 24, 2021
    Vikashlb , via OnePlus 6T , Aug 24, 2021 :
    use the rollback package.
    D.Sai Suhail Baba likes this.
  5. rohitsharma_j22
    Gingerbread Aug 24, 2021
    rohitsharma_j22 , Aug 24, 2021 :
    Why Pop on screen option for Messages app notification is always on, it is found disabled under notification settings, so can't change it too. I dnt want them to peak out everytime on recieving SMS.
  6. rohitsharma_j22
    Bro try following solutions. It started working for me:
    1. Disable RAM Boost.
    2. Under Battery Optimization>Advanced Optimization, Disable the "Sleep Standby Optimization" and Optimise App Power Consumption" options
    3. Go to App Info of Gmail App, Unde Batter section select "Don't Optimize" option.
    4. Again in App Info of Gmail, go to Permissions. At Bottom disable "Remove permissions if app isn't used" option.
    5. Restart your phone.
    Hope above steps will work for you. Its working fine on my OP6 after following above steps.
  7. LegolasX
    KitKat Aug 24, 2021
    LegolasX , Aug 24, 2021 :
    there must be something wrong during update. Android 11 comes with Phone 5.0
  8. ak2win
    Donut Aug 24, 2021
  9. Vaibhav132
  10. GaneshKunte
    GaneshKunte , Aug 24, 2021 :
    WTF, its sunny out there in the middle of noon hot outside.. But in the launcher showing night weather.
  11. GaneshKunte
    Extra white space in the bottom even though I have selected hide in the keyboard settings.
    From 2 days it wasn't there. Suddenly from few mins I started getting this.
    K1577555224305 likes this.
  12. U1629788722851
    U1629788722851 , Aug 24, 2021 :
    This upgrade appears to randomly delete certain apps and their data. These apps are ones I have written and installed using adb . Not all my apps are getting removed, just seems to be those using SQLITE databases. Can anyone explain why this happening.
    Also I would like to switch off automatic OS update on my other phone, so I don't lose apps installed on there. But can't see obvious way to prevent automatic upgrade to Oxygen 11
  13. swapnil.s
  14. FaleshC
    KitKat Aug 24, 2021
    FaleshC , Aug 24, 2021 :
    changelog is displayed only if device is updated via OTA.
    you won't see changelog if you update manually using zip file.
  15. ak2win
    Donut Aug 24, 2021
    ak2win , via OnePlus 6 , Aug 24, 2021 :
    That's why I'm asking. I got the update throught the official OTA channel today. After the update there is no changelog under system updates menu.
  16. FaleshC
    KitKat Aug 24, 2021
    did you factory reset after update?
  17. ak2win
    Donut Aug 24, 2021
  18. FaleshC
    KitKat Aug 24, 2021
    factory reset wipes the changelog. nothing to worry about that.
    ak2win likes this.
  19. ak2win
    Donut Aug 24, 2021
