408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. kouzelnik3
    Ice Cream Sandwich Aug 26, 2021
    kouzelnik3 , Aug 26, 2021 :
    Factory reset and you will be ok.
  2. G1617203943957
    Eclair Aug 26, 2021
  3. balluxlent
    Froyo Aug 26, 2021
    balluxlent , via OnePlus 6 , Aug 26, 2021 :
    I did the same what u said,but its stil auto getting ON in location setting.
  4. balluxlent
    Froyo Aug 26, 2021
    I stil need to scroll down system icons and switched it off mannualy🥺
  5. Shivam2711
    Cupcake Aug 26, 2021
  6. Auristic
    Lollipop Aug 26, 2021
    ItsRavi25 likes this.
  7. G1617203943957
    Eclair Aug 26, 2021
  8. rakeshgergal
    Froyo Aug 26, 2021
    hybridxo7 likes this.
  9. Auristic
    ItsRavi25 and D.Sai Suhail Baba like this.
  10. Akak009
    Akak009 , via OnePlus 6T , Aug 26, 2021 :
    How to back to android 10 ?
  11. andrewirwin
    andrewirwin , Aug 26, 2021 :
    I installed the update and now I do not have mobile data. I spoke to Oneplus tech support, they gave me a set of steps to follow to set the phone to work with TELUS again. I followed the instructions and when I went to save it I got an error message. "Carrier does not allow adding APNs of type*."
    The tech said to phone Telus to have them unblock the APN.
    Telus said they can't do that, it is the software update, Oneplus did not allow for Telus. Oneplus now say I should switch providers
  12. 01rish
  13. shyam1995
    Donut Aug 26, 2021
    shyam1995 , Aug 26, 2021 :
    it's not always on display, they didn't said about that, didn't mentioned right
  14. vinodnair94
    vinodnair94 , via OnePlus 6 , Aug 26, 2021 :
    Bluetooth stopped automatically connecting to previously connected/paired devices like oneplus bullets 2. This was working seamlessly on oxygen os 10.
    Any fix/workaround?
  15. E1542843341067
  16. Feroz_Mohammed
    Gingerbread Aug 26, 2021
    E1542843341067 and karaj_h35 like this.
  17. Feroz_Mohammed
  18. Feroz_Mohammed
    Feroz_Mohammed , via OnePlus 6 , Aug 26, 2021 :
    Yes, it's a bug. Report to OnePlus. Your report matters alot.
    premfroster, hybridxo7 and karaj_h35 like this.
  19. premfroster
    Donut Aug 26, 2021
  20. A1550387522048
    Honeycomb Aug 26, 2021
    A1550387522048 , via OnePlus 6 , Aug 26, 2021 :
    After a week I observed the global performance is good except the on-screen/display in use battery consumption. Even the OS 11 system battery consumption shows 8 hours 35 minutes for 33% of drain reality is not going parallel to that. Each 5 minutes max on screen drains 1% of the battery charge..this is high...please improve the battery discharging. Rest of all very good.. exciting. Thanks.
