408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. Goanspidey02 , via OnePlus 6 Mirror Black , Aug 27, 2021 :
    If you know it, please let me know the same
  2. Auristic
    Lollipop Aug 27, 2021
    ItsRavi25 likes this.
  3. Auristic
    Auristic , Aug 27, 2021 :
    As I told you I'm not here to spoonfeed you: all is written in this thread...
  4. Auristic
    Using the search function is easy, you should try that...
    It will take me the same amount of time as you to find the message but since I don't have this issue you'll understand I won't do your job.
    But since you seem nice and I'm in a good mood, there you are...
    ItsRavi25 and rhyd1am like this.
  5. 18aniruddha
    Honeycomb Aug 27, 2021
  6. Auristic
    Don't worry I know the answer...
    I was simply waiting for a reply from @L1555786502583 since I find it highly unlikely that a Cupcake using a 3 years old device finds out by himself how to rollback from 11 to 10.
    In case you didn't notice it this thread is being trusted by trolls and fake accounts since 11 was released for OP6/T...
    Consider this as a social experiment.
  7. xxxwolverine
    Donut Aug 27, 2021
    xxxwolverine , via OnePlus 6 , Aug 27, 2021 :
    Facing Google account login problem for cod mobile game. When I try to link it says account link unsuccessful.
    after updating to android 11 only I'm getting this issue.
    Anyone facing this issue? Any fix?
  8. H1557058226130
    Gingerbread Aug 27, 2021
    H1557058226130 , via OnePlus 6T , Aug 27, 2021 :
    Thanks for update ....
    Battery drains too much ,
    Hidden space password not working,
    There is no use from App locker ... Error when trying to open...
    Launcher : no edit option to change icons size & font ( only 2)
    I love customized AOD, ICON Optimization of os11 ..thanks to oneplus
    #love u oneplus
  9. O1546363847417
    Cupcake Aug 27, 2021
  10. kouzelnik3
    Ice Cream Sandwich Aug 27, 2021
    kouzelnik3 , Aug 27, 2021 :
    Factory reset is recommended after major update, so you can try that.
  11. Geetanjali0205
    Donut Aug 27, 2021
    Geetanjali0205 , via OnePlus 6 , Aug 27, 2021 :
    I am facing issues after the upgrade. I am not getting gmail app notifications. The notifications are turned on. Sync is turned on. I receive them when I open the app and it refreshes itself
  12. O1546363847417
  13. kouzelnik3
    Uh :/ Maybe you can try flash the same ROM? Or maybe downgrade to A10 OOS10 and eventually update again?
  14. O1546363847417
    O1546363847417 , via OnePlus 6T , Aug 27, 2021 :
    Went to OnePlus Store as well they did some software downgrade to A9 and again updated to os11 but still facing the issue.. they told me its might be motherboard issue and needs a replacement. Just don't understand that how 1 software upgrade damage the motherboard. Before update it was working fine.
  15. Abhi131989
    Eclair Aug 27, 2021
  16. Auristic
    Exactly like my car: before breaking down it used to run perfectly...
    Ever heard about coincidences!?
  17. O1546363847417
    Lol.. yes i heard but i did not like this coincidence at all ...😅
    D.Sai Suhail Baba and Auristic like this.
  18. H1563345910306
    H1563345910306 , via OnePlus 6T , Aug 27, 2021 :
    Camera app is crashing with this new oxygen 11 update...... oxygen OS 11 not optimised completed. Try to make a clean and bug free Ui before releasing a stable release......ver disappointed with this new update...😡
  19. L1555786502583
