408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. Prof_0007
    Froyo Aug 28, 2021
    Prof_0007 , via OnePlus 6 , Aug 28, 2021 :
    Yeah i faced that too for a while and it got fixed later.
  2. kouzelnik3
    Ice Cream Sandwich Aug 28, 2021
  3. K1577555224305
    Honeycomb Aug 28, 2021
    K1577555224305 , Aug 28, 2021 :
    How can do that.. its 2009 Mb and 2095Mb since release 🤔🤔
  4. mlksurat
    Cupcake Aug 28, 2021
  5. D.Sai Suhail Baba
    Jelly Bean Aug 28, 2021
    D.Sai Suhail Baba , Aug 28, 2021 :
    To fix some bugs they'll remove or will add codes which causes change in Size of OOS 11.
    Caomhin and Auristic like this.
  6. Etn_26
  7. D.Sai Suhail Baba
  8. K1577555224305
    No actually I meant there are only 2 sizes or maybe 3 for each 6 series devices 2009 for 6 and 2095 for 6T or MacL ed.
    They have not changed since Stable release. Then how can you say the codes are changed or add etc.
  9. D.Sai Suhail Baba
    By changing codes bugs are fixed in Software Update. Size differs based on hardware and device specific features.
    Sometimes size will be same .
  10. K1577555224305
    But then the file name should also change in OTA file. Did you check it.
  11. D.Sai Suhail Baba
    Why file name should be changed. They are fixing bugs related to software changelog only. New bugs will be fixed in new Software Update.
    Caomhin likes this.
  12. Etn_26
    Etn_26 , via OnePlus 6T , Aug 28, 2021 :
    Ok then there I will get stable version in the normal software update section?
  13. D.Sai Suhail Baba
    Downgrading will wipe out your device data completely. Take backup of your device data and downgrade.
    Caomhin likes this.
  14. D.Sai Suhail Baba
    You'll receive OOS 11 Software Update via OTA , may receive within 5 - 6 days after downgrade.
    Caomhin and Etn_26 like this.
  15. Etn_26
    Is there any official link for downloading the software so that I can local upgrade?
  16. K1577555224305
    You are telling, that people are getting bug fixed updated in batches..
    I don't think that OnePlus will perform such a discrimination.
    Every one is getting the same ROM OTA .
    When the bugs will get fixed again everyone would get the same but at different rollout stages.
  17. D.Sai Suhail Baba
    Wait for OTA it's always better you'll receive bug fixed OOS 11 update.
    Caomhin likes this.
  18. D.Sai Suhail Baba
    This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs
    Caomhin likes this.
  19. Amalshaju778
  20. Auristic
    Lollipop Aug 28, 2021
    Caomhin likes this.
