408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. adi1001
    Honeycomb Aug 28, 2021
    adi1001 , via OnePlus 6T , Aug 28, 2021 :
    How many days this is valid?....i means till what date it is operational ?...do u know abt this anything ?
  2. Gery S.
    Eclair Aug 28, 2021
    Gery S. , via OnePlus 6 , Aug 28, 2021 :
    This company never listen to their costumers!
    A LOT of people complain for YEARS now that there is no separate volume for ringtone and notification, and oneplus doesn't give a shit!
  3. HoraceBaxter
    Donut Aug 28, 2021
    HoraceBaxter , via OnePlus 6T , Aug 28, 2021 :
    Hi community! Couple of issues with the new 11 upgrade. Some battery drain but more of an issue is SMS/MMS problems and cannot use mobile data away from home. Pics attached. But otherwise love the upgrade. Would a reset help? Thanks.
    K1577555224305 likes this.
  4. D.Sai Suhail Baba
    Jelly Bean Aug 28, 2021
    Caomhin, Royal_RJ and Auristic like this.
  5. 18aniruddha
  6. 18aniruddha
    18aniruddha , Aug 28, 2021 :
    it isn't fully stable yet. there are few bugs which needs to fixed
  7. 18aniruddha
    you can use oxygen updater.
    it's available on play store
  8. 18aniruddha
    downgrade to Android 10 using rollback package
    (check the beta thread you will find rollback package there)
    Note: Downgrading leads to full data wipe so before doing it take backup
  9. L1556648266777
    Cupcake Aug 28, 2021
  10. L1556648266777
  11. Saptakc
    Froyo Aug 28, 2021
    Masteroogway likes this.
  12. Auristic
    Lollipop Aug 28, 2021
    Auristic , Aug 28, 2021 :
    Then carry on waiting SILENTLY!
    Caomhin and ItsRavi25 like this.
  13. G_Raghu_Oza_QHSl
    Donut Aug 28, 2021
    G_Raghu_Oza_QHSl , via OnePlus 6 , Aug 28, 2021 :
    Battery 🔋 drains quickly after android 11 update. Showed it in service center they say it's because of latest update.
    Did anyone come across this issue?
    Pls revert back.
  14. tarinimishra
    Froyo Aug 28, 2021
    tarinimishra , via OnePlus 6 , Aug 28, 2021 :
    I too have the same isuue.
  15. mr.mhsayan
    mr.mhsayan , via OnePlus 6T , Aug 28, 2021 :
    Whenever I'm rotating my phone for playing game, watching movie than this thing is happening with me. Is there any one who is facing this same problem?
  16. Ankurvamp92
    Froyo Aug 28, 2021
    Ankurvamp92 , via OnePlus 6 , Aug 28, 2021 :
    Yes you are right after updating to android 11 it is draining like hell but it is used to be better in the very begining of the update but since couple of days it has been draining fast ...
  17. Harsha44
  18. S v Lakshmi Reddy
    Froyo Aug 28, 2021
  19. E1577213299704
    E1577213299704 , via OnePlus 6 , Aug 28, 2021 :
    Yeah , I am also facing same issue of battery drain after android 11 update.
    Ankurvamp92 likes this.
  20. ItsRavi25
    ItsRavi25 , Aug 28, 2021 :
    Try this
    Gmail notifications issue, follow the steps below:
    1. Disable RAM Boost.
    2. Goto > Settings > Battery >Battery optimisation > Right top corner 3 dots > Advance optimisation > Disable sleep stand by and optimise app power consumption.
    3. Go to App Info of Gmail App, Unde Batter section select
    "Don't Optimize" option.
    4. Again in App Info of Gmail, go to Permissions. At Bottom
    disable "Remove permissions if app isn't used" option.
    5. Restart your phone.
    Caomhin and Auristic like this.
