408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. Puffer_18
    Eclair Aug 29, 2021
    Puffer_18 , via OnePlus 6T , Aug 29, 2021 :
    Should i get original update..?
  2. 18aniruddha
    Honeycomb Aug 29, 2021
    18aniruddha , Aug 29, 2021 :
    as i said both are same.
    it's upto you. only if you're running out of patience go for oxygen updater else wait for official OTA.
  3. rhyd1am
    KitKat Community Expert Aug 29, 2021
    rhyd1am , Aug 29, 2021 :
    The file that the Oxygen updater app uses is taken from the exact same server that the update from OnePlus comes from.
    As mentioned below, if you're unsure then just wait.
    rHITkM. and Caomhin like this.
  4. HoraceBaxter
    Donut Aug 29, 2021
    HoraceBaxter , Aug 29, 2021 :
    Yes I know. When WiFi is off I cannot connect to Mobile Data. It does not work. Solution?
    K1577555224305 likes this.
  5. A6000
    Donut Aug 29, 2021
    A6000 , Aug 29, 2021 :
    After updating via OTA (andriod 11) my OP6 my phone went into Qualcomm CrashDump mode... (from past couple of days phone is behaving weird) it hangs & restarts for no reason.. Its never been like this before.
    i have done full reset after updating before using it. Thanks to Oneplus for giving buggy update and F**** up my phone.
    K1577555224305 and anky_0211 like this.
  6. ItsRavi25
    Jelly Bean Aug 29, 2021
    ItsRavi25 , Aug 29, 2021 :
    Use oxygen updater app for faster update.
    Update to latest version, do backup and reset your device.
    D.Sai Suhail Baba likes this.
  7. daanand
    Donut Aug 29, 2021
  8. popxunga
    Eclair Aug 29, 2021
    popxunga , Aug 29, 2021 :
    And is the installation process itself fully equivalent to the update process via OTA ? I mean, will we get the same exact results either updating via Oxygen Update or via OTA ?
  9. adi1001
  10. adi1001
  11. rhyd1am
    The only difference will be that you won't see a change log, but everything else is exactly the same since it's the exact same file.
    D.Sai Suhail Baba and popxunga like this.
  12. surendra91
  13. rhyd1am
    Never (unless you use a custom ROM).
  14. G1617203943957
    Eclair Aug 29, 2021
  15. rhyd1am
    K4ndym4n likes this.
  16. sagar_b
    Eclair Aug 29, 2021
  17. rhyd1am
    No problem 👍
  18. hugocorreia78
    Gingerbread Aug 29, 2021
    hugocorreia78 , via OnePlus 6 , Aug 29, 2021 :
    This Oxygen it's good, but need some updates.
    The camera have some bugs. The auto-focus It's not good, and bokeh mode too.
    The screen light it's poor. The always-is-on some times dont shows all the notifications. When we dial a call the screen turn off.
    But It's fine to have some phone who have 3 Android systms. May be this os the last on.
