408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. Ankita_S.
    OnePlus Bug Hunter Staff Member Aug 30, 2021
    Ankita_S. , Aug 30, 2021 :
    We have responded to your concern via DM, please check for the same and respond with the required information at the earliest.
  2. kouzelnik3
    Ice Cream Sandwich Aug 30, 2021
    kouzelnik3 , Aug 30, 2021 :
    Try to look through this thread and you would find answers on all of your issues and how to solve them eventually :)
    Auristic likes this.
  3. drkrishna
    Gingerbread Aug 30, 2021
    drkrishna , via OnePlus 6 , Aug 30, 2021 :
    After almost a week of using oxygen os 11, battery drain is the only issue I felt. Media storage is consuming lot of battery power. Have to charge 3 or 4 times a day. Rest of the update works fine. I think OnePlus can fix this issue with an update.
  4. G1537763819734
    Donut Aug 30, 2021
    G1537763819734 , via OnePlus 6 , Aug 30, 2021 :
    Wow extreme battery drain... I updated the day android 11 was released for oneplus 6. It heats up and drains the battery... Damn should never had upgraded :(
  5. G1537763819734
    Donut Aug 30, 2021
  6. ravimoon
    Cupcake Aug 30, 2021
    ravimoon , Aug 30, 2021 :
  7. rhyd1am
    KitKat Community Expert Aug 30, 2021
  8. A1630328454624
  9. Akshat2793
    Akshat2793 , via OnePlus 6 , Aug 30, 2021 :
    Amazing to see how proactive Ankita is. Thanks for your help!
  10. abhi7818
    abhi7818 , via OnePlus 6T , Aug 30, 2021 :
    I'm using 6T. Since update Mobile is not working properly. I updated it yesterday & since then speed has gone drastically down. Many apps are not working properly. Bluetooth connectivity is not working properly. M unable to see all the pics in the gallery. Please resolve these issues.
  11. L1574619355815
    L1574619355815 , via OnePlus 6 , Aug 30, 2021 :
    Thanks OnePlus team for OS11 update, it's running pretty smooth. As understood from previous post, with OS 11 update, we will able to use audio streaming in hearing aids through bluetooth. Unfortunately, it's still not working for me. Can we please get a. ASHA update for OnePlus 6.
  12. Quentin79
    Froyo Aug 30, 2021
    Quentin79 , Aug 30, 2021 :
    Since upgrade to OxygenOS 11 my Oneplus 6T suffers of battery drain when using mobile data. Everything is OK under wi-fi data. I analyzed the phone with betterbatterystats and I found the culprit is the phone services app that under mobile data connection prevents the phone going to the deep sleep state with a wakelock called "telephony radio". My signal reception is good and I had no problems with OxygenOS 10, all started with the OxygenOS 11, I performed a wipe cache from recovery just after the update.
  13. surensrini
    Donut Aug 30, 2021
  14. ashishlp007
  15. snopkowsky
    snopkowsky , Aug 30, 2021 :
    My wi-fi connection is not stable, dropping multiple times after some minutes and then immidiately reconnect back.
  16. A6000
    Donut Aug 30, 2021
    A6000 , Aug 30, 2021 :
    WARNING : Do not update your OP6 now/in future updates... Casue Oneplus is playing with older devices by giving buggy updare (scaling down performance of phone - reducing processor speed, apps are like running in background without optimization, overheating - and ending up device in non bootable mode)
    JUST THE WAY APPLE DID WITH THERE IPHONES IN PAST..
  17. gaurav092003 likes this.
  18. stmise
    stmise , via OnePlus 6T , Aug 30, 2021 :
    After updating to android 11 I can't install apps from unknown source, like from chrome...just from Google play..anybody else have this problem?
  19. W1630339100498
    W1630339100498 , via OnePlus 6 , Aug 30, 2021 :
    On OnePlus 6, after upgrading to oxygen 11:
    - android auto is not working anymore with my car, whereas it worked perfectly before
    - Google fit doesn't count my steps anymore
    I tried to clear cache/data for these both apps but it's still not working.
    Thx for your help
