408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. 18aniruddha
    Honeycomb Sep 6, 2021
  2. 18aniruddha
    18aniruddha , Sep 6, 2021 :
    Downgrade to Android 10 using Rollback Package then you'll be able to update to Android 11 stable.
  3. 18aniruddha
    under the beta thread you'll find rollback packages for 6 and 6T.
    download the rollback package
    keep it under root folder
    goto settings>system>system update
    click on the settings icon on the top right hand side and then click on local upgrade and select the roll back package.
    Warning: Downgrading will wipe all your data so before Downgrading take a safe backup
  4. Q1625987599948 , via OnePlus 6T Mirror Black , Sep 6, 2021 :
    Will there be any problem with mobile if you do this?
  5. 18aniruddha
    No. this is the only way you can move to stable from beta.
  6. upthera
    Froyo Sep 6, 2021
    upthera , Sep 6, 2021 :
    Has anybody actually had the OTA in the last 10 days?
    Severely doubt it.
    Has to have been pulled because it's that buggy.
    No way an incremental roll out would be a month otherwise.
    ** They're using the twats that update by the Oxygen app as surrogate Beta Boys lol.
  7. kouzelnik3
    Ice Cream Sandwich Sep 6, 2021
    kouzelnik3 , Sep 6, 2021 :
    I am wondering why people are flashing beta builds when then they want to go back to stable but dont know how. Is it really that hard to read few lines in the thread - usually in first post?
    Caomhin, jeeva256, Vikashlb and 2 others like this.
  8. Phanilkumar
    Gingerbread Sep 6, 2021
  9. D1550392890266
    Eclair Sep 7, 2021
  10. D1550392890266
    Eclair Sep 7, 2021
    D1550392890266 , via OnePlus 6T , Sep 7, 2021 :
    Can you share a battery update? How good it is and what is the idle drain?
  11. iampg
    Donut Sep 7, 2021
  12. Apurv_Kumar09
    Cupcake Sep 7, 2021
    Apurv_Kumar09 , via OnePlus 6T , Sep 7, 2021 :
    Hi All,
    Is there any OnePlus 6T user who is also observing Pocket Mode error even when the Phone is not covered? I am seeing this alot on my phone post Android 11 update and a restart fixes it temporarily. Is this a bug? Does anyone have a solution for this?
  13. ItsRavi25
    Jelly Bean Sep 7, 2021
    ItsRavi25 , Sep 7, 2021 :
    Do all you backup, and reset your device. It's advised to reset your device once when there is some major update.😇
    Caomhin likes this.
  14. ItsRavi25
    A month 😶
    STAGED ROLLOUT
    As majority of users received the Update, Maybe they will release throughout the boarder in few days or by next week.
    For faster update use OXYGEN UPDATER app.
    upthera and Caomhin like this.
  15. ashish2201
    Cupcake Sep 7, 2021
    RRAI likes this.
  16. F1630863556072
    Cupcake Sep 7, 2021
  17. D1550392890266
    Eclair Sep 7, 2021
    Is the build even stable? I have read mixed reviews from different people so jumping onto oxygen updater isn't the solution if the build breaks your daily driver.
  18. ItsRavi25
    To be honest, for gaming it's working for me ( Mid lvl games, not too high graphics FPS games)
    Getting 8 TO 10+ SOT depends on usage. ( Using Wifi most of time)
    Rest everything is working smooth, it can be use as daily drivers.
    Update via OTA and oxygen updater is same and safe.😇
    Caomhin, Auristic and D1550392890266 like this.
