408
OxygenOS 11 for the OnePlus 6 and OnePlus 6T
  1. Auristic
    Lollipop Sep 12, 2021
    ItsRavi25 likes this.
  2. Auristic
  3. Auristic
    Auristic , via OnePlus Community App , Sep 12, 2021 :
    So you know you've got only the wait option left since you don't want to use Oxygen Updater.
    I reckon this is stupid (this app is perfectly safe and easy to use) but since this is YOUR choice please wait SILENTLY because here nobody can do anything for you.
    Thanks for your understanding.
  4. T1548088903594
    Eclair Sep 13, 2021
  5. K1598104281626
    Cupcake Sep 13, 2021
  6. ItsRavi25
    Jelly Bean Sep 13, 2021
    ItsRavi25 , via OnePlus 6T , Sep 13, 2021 :
    Yes I will share the battery stats.....once I charge my device to 100% and use it till 0%.
    Auristic likes this.
  7. D1534398127817
  8. samir23
    Donut Sep 13, 2021
    samir23 , via OnePlus 6 , Sep 13, 2021 :
    The battery is draining unexpectedly and the phone needs to be charged atleast twice to run through the day of normal use. Seems the device is making up for all the good days of excellent battery backup it gave prior to the latest update.. extremely disappointed...😠😠
    Sureshsouravk likes this.
  9. samir23
    Donut Sep 13, 2021
  10. FaleshC
    KitKat Sep 13, 2021
    FaleshC , Sep 13, 2021 :
    works fine on my OnePlus 6. however I wish it could be turned off.
    LegolasX and K1577555224305 like this.
  11. samir23
    Donut Sep 13, 2021
  12. FaleshC
    KitKat Sep 13, 2021
    turn on ambient display for incoming messages, Horizon light is On by default.
    LegolasX likes this.
  13. samir23
    Donut Sep 13, 2021
  14. K1577555224305
    Ice Cream Sandwich Sep 13, 2021
    K1577555224305 , Sep 13, 2021 :
    Well in that case you can give OnePlus feedback on this issue so they could rectify in the coming updates.👍[/QUOTE]One plus feedback system is like a black hole.
  15. UshasDev , via OnePlus 6 Amber Red , Sep 13, 2021 :
    Check your RAM in developer option, i too have the same issue very frequently, as the Android OS use most of the ram the other apps won't get enough juice to work properly so they misbehave.
    Do check inside the developer option.
  16. Gery S.
    Eclair Sep 13, 2021
    AniketM97 and B.J.R.G like this.
  17. T1529654676065
    Froyo Sep 13, 2021
  18. A1594910915738
    Honeycomb Sep 13, 2021
  19. TheOne299
    TheOne299 , Sep 13, 2021 :
    Haven't seen the update either in the system update section. When i do a system update check it says I'm up to date.
    (On the last OTA 10 version)
  20. A1594910915738
    A1594910915738 , Sep 13, 2021 :
    i think its mentioned like 1000 times that you can use oxygen downloader tool
